DIY linear tonearm
DIY linear tonearm
Old Today, 06:22 AM   #4051
Mike56 is offline Mike56
Originally Posted by directdriver View Post
I've been busy and have not been able to follow the thread closely but I like what I am seeing in the direction of this thread, thanks to Carlo (again) and Mike,
I was drawn to Carlos work and others on here and that's what interested me enough to have a go, but i don't have the tools to do any machining so its done by hand.
why not making it about 4 inches long so it can hover over to the end of record area
A month or two back i would have agreed, now i have observed and learnt to keep every lever short and torque avoided. When i built my first, it tracked fine and played ok except it pivoted on the single rail parallel to the groove under the combined influence of stylus drag and warp movement and the varying vertical lever associated with that. Those things are still there and controlled by the second stabiliser rail which of course sees varying loads and causes drag/friction.
So now i have learnt what is meant by avoid long levers the hard way and so i shall try and make the current contraption work and then pivot the whole assembly at the base off the platter for record loading, exactly as one does with a pivot tone arm, unless i see a better suggestion first. mike
PC, to Chordette GEM DAC or O.L. Aurora4 with Onyx arm Rega Ania to Graham Slee MC pre, to Prima Luna Prologue 1. Troels Gravesen Fusion BAD with Hypex 151's high level input
  Reply to this post
DIY linear tonearmHide this!Advertise here!
Linear tracking tonearm vs. Pivoting tonearm Don Nebel Analogue Source 5 31st May 2015 03:55 AM
Another DIY Tonearm johnmarkp Analogue Source 0 21st April 2008 11:07 PM
my DIY Turntables and DIY tonearm Roger Waters Analogue Source 57 22nd January 2008 06:05 PM
Magnetic suspension linear-tracking tonearm? Shaun Analogue Source 5 4th June 2003 10:21 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
