DIY linear tonearm
DIY linear tonearm
Old Yesterday, 02:41 PM   #3871
hottattoo is offline hottattoo  United States
Here is a great source of jewel bearings / pivots for those making a linear tonearm. I got my bearings from them. USA source. Good luck
https://birdprecision.com/
Joe
Old Yesterday, 02:54 PM   #3872
Apache100 is offline Apache100  United Kingdom
Best way to be sure is to try it!
Even Rega don't list the compliance figures for that cart on their website! Odd, as it's pretty important wrt the mass of your arm. Being MC though, I would have thought it will be low to medium compliance.
Old Yesterday, 04:50 PM   #3873
Mike56 is offline Mike56
I think its the only working cartridge i have........an old ortofon vms 20e lurks around in a box, but is not comparable and needs different amp etc, it may not work either, so the Rega it will be, when i have the bits and assemble it all something will be revealed!!
PC, to Chordette GEM DAC or O.L. Aurora4 with Onyx arm Rega Ania to Graham Slee MC pre, to Prima Luna Prologue 1. Troels Gravesen Fusion BAD with Hypex 151's high level input
Old Yesterday, 04:52 PM   #3874
Bird Precision
Joe
Thanks for that, i also got a nice response from Dave at Swiss jewel, copied below, i may go the jewel way later!
Thank you for this inquiry- we have a few successful Tonearm customers and they implement our
Sapphire vee-jewels and pivots,
www.swissjewel.com
you can click on products then click on pivot
and then click on jewel bearings, and find “sapphire vee-jewels”
for tonearm gimbal pivots - the radius of the pivot should be 1/3rd less than the radius of the vee jewel – for a frictionless environment.
You can see the prices and buy a al care online
Average prices for vee-jewels and pivots are under $10 per piece with a $5.30 average price unit.
Old Yesterday, 08:06 PM   #3875
I'm about to experiment with this.
I've been thinking about an electronic way of applying lift / lower, but have got a bit carried away! This is the entire vertical movement part of the arm, using a de-sealed linear bearing, with the rod changed to acrylic so it doesnt carry the mag field to the cartridge. Lift / lower (and possibly tracking force) can be applied by activating the solenoid (probably slugged with a biggish capacitor to avoid rapid ascent and descent.
I'm thinking it may be possibly to apply tracking force by varying the voltage on the solenoid. It's a 6v for 30g pull one, (may not be sufficient but it's what I had around)
I've just put it together as a trial fit (I need to 'loosen' the link between solenoid and acrylic rod as it's a little tight) and just see what range of force I have, and then borrow a gauss meter from work to ensure I don't have too much field at the cartridge position.
Experimental at the moment, but would be neat if it works.
<edit>
Variable tracking force wont be possible with this type of solenoid, as the amount of pole piece inside the coils varies with the position. Duh, should've spotted this. It will require one with the pole piece passing right through and always being within the coils.
Old Yesterday, 10:12 PM   #3876
warrjon is offline warrjon  Australia
Because Rega expect you to use ALL their gear. I had an Apheta 2 and it was the worst cartridge I have ever had, sold it with less than 20hrs. My current Technics EPC205 with a Jico SAS out performed it in every way.
I suspect the Rega MC'c are very low compliance as I could hear music coming off the tonearm on the RP8/RB808/Apheta 2 from my listening position with the volume turned down.
SP10, ...... DIY Linear tonearm, ......Stanton 881s with D3000 stylus, .....BHL phono,.........Pass B1,
MODULUS 86 power amps x4,.............Active line level OX,......... bi-amped OB speakers with Mark Audio Alpair 12P
Old Today, 03:08 PM   #3877
super10018 is offline super10018  United States
<edit>
I tried solenoid to do the lift with wireless remote control on my air-bearing arm. However, my application was different from yours. The cartridge picked some noise from the solenoid so I had to give it up although the noise level was very low.
DIY linear tonearmHide this!Advertise here!
Linear tracking tonearm vs. Pivoting tonearm Don Nebel Analogue Source 5 31st May 2015 03:55 AM
Another DIY Tonearm johnmarkp Analogue Source 0 21st April 2008 11:07 PM
my DIY Turntables and DIY tonearm Roger Waters Analogue Source 57 22nd January 2008 06:05 PM
Magnetic suspension linear-tracking tonearm? Shaun Analogue Source 5 4th June 2003 10:21 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
