DIY linear tonearm
DIY linear tonearm
Old 30th June 2020, 12:02 PM   #3811
Apache100 is offline Apache100  United Kingdom
Originally Posted by Mike56 View Post
Sorry to keep asking, i know i have seen it somewhere, what is the best wiring thought currently please (at reasonable cost)?
In the UK, 'The Scientific Wire Company' stock reels of fine Litz at sensible prices.
Old 30th June 2020, 01:34 PM   #3812
Mike56 is offline Mike56
Originally Posted by warrjon View Post
I modified the carriage today. Removed the 3mm thick carbon fibre bottom and installed 2x 0.5mm carbon fibre at 90deg this raised the bottom of the carriage allowing me to lower the VTA, reset the wheels this time with a depth micrometer instead of a ruler. Set the rail up on the granite surface plate and measured the rail and the carriage for straightness the rail was 0.01mm over it's 200mm length but the carriage was 0.1mm which I suspect was due to me removing the polycarbonate grub screw holders and re-installing them.
This time I set the rail level by the front of the cartridge not by a level on the rail. This will have the rail tilting down towards the centre but not enough to cause any issues as I have now played all the problem LP's and so far so good.
Voila - distortion totally gone.
I am intrigued to know which action improved the distortion, i am edging closer to build and i remember reading about rail slope to centre to provide the move to centre force, is it that or better VTA? - or something else!
PC, to Chordette GEM DAC or O.L. Aurora4 with Onyx arm Rega Ania to Graham Slee MC pre, to Prima Luna Prologue 1. Troels Gravesen Fusion BAD with Hypex 151's high level input
Old 30th June 2020, 01:36 PM   #3813
Excellent thanks, would they do connectors as well?
Old 30th June 2020, 01:43 PM   #3814
Originally Posted by koldby View Post
You could even change the direction of the parallelogram like in pic. 1 I think the balance in the hole system will improve.
And instead of the difficult to produce wheel and pin bearings , you could use the suggestion in pic. 2. This straight ball bearing is in fact the basis for the Lil casey rail, described in this thread:
My Linear Tracker (a new variation perhaps?)
By using two rails you avoid the pivoting action of just one rail.
Thanks, I did draw it like that originally Koldby but i thought that keeping the parallelogram movement in line with the rail allowed the stylus to remain centred on the groove in case of warp (hoping the resistance/friction load would be insignificant)whereas the other way there was no automatic compensation and you would get a warp wow, but might not matter.
I am not sure yet how big the con rods etc should be, a sketch might follow as i collect parts and i greatly value input prior to making mistakes.
For me this is a low budget exercise and i have a two ball bearing on borosilicate in mind to start with, aim is <100 even with most parts being over quantity!
Old 30th June 2020, 02:04 PM   #3815
I'm not sure. I had a 50m spool of fine litz from them, but didn't look for connectors. They're not specifically an audio supplier though. If it's cartridge pins you need, find an old D-Type socket and cut it apart.
Old 30th June 2020, 02:59 PM   #3816
Many thanks, i might just go with a few 's on Amazon but i will check them out first.
Now i apologise for the sketching, but my "ideas shamelessly borrowed off others" (ISBOO) design currently looks like this attached. Hope its understandable....
Cheap and simple approach but hopefully mostly proven and addressing a good percentage of the important aspects. Cut and glue bits of carbon and bolt on the bearings.
I will do a basic glass tube track and then see how to refine it later.
I haven't done the weights, centres and levers yet, but i think the proportions feel about right?
Please tell me what is obviously wrong with it? - and any suggestions on dimensions much appreciated as well.
Old 30th June 2020, 03:05 PM   #3817
Hi There Apache, i just checked their site and found myself in the deep end again, i didn't see specific mention of Litz, but now realise that is a generic description and i need to know more detail of sizes etc.
i shall research, any info most welcome as well!
Old 30th June 2020, 08:36 PM   #3818
koldby is offline koldby  Denmark
koldby's Avatar
Your arguments is exactly the ones I would use to have the parallelogram in line with the GROOVE as it is in my suggestion . Then you have no sideways movement in the groove, as opposed to having the parallelogram in line with the rail.
Another thing is if you use only one rail, you can get a pivoting movement in the rail, whereas if you use two rails there are no pivot action as in carlos and in my models
What is Home Theatre without good sound?
Old 30th June 2020, 09:11 PM   #3819
But two rails is two lots of friction which seems to have been a major problem.
I don't know the answer! i wish to be minimalist. look forward to other input! mike
Old 30th June 2020, 10:42 PM   #3820
warrjon is offline warrjon  Australia
Hi Mike,
The issue I see with this design is you have a double vertical pivot. The carriage can pivot on the rail and the cartridge is attached to a vertical pivot. With 4mm rods you will need 3mm wide bearings to sit them at the correct angle on the rail. 6mm rods require 4mm bearings.
To answer your question I suspect the distortion improvement was mainly due to being able to adjust the stylus in the groove afforded by the shallower carriage. Probably more to do with azimuth than VTA. I originally set the rail level and did not worry about checking azimuth as I machined everything to close tolerances. I didn't take into account removing and re-gluing the wheel mounting blocks.
I played quite a few LP's last night and the distortion is significantly better but I can still hear some distortion on the right channel on the inner groove during heavily modulated passages especially female voice. Increasing VTF improved but did not eliminate it. My wife can't hear it but I know it's there.
Tonight's tests will be to adjust the rail which changes azimuth to see if I can completely eradicate the distortion. If this fails I will make another carriage that has azimuth adjustment so the rail can be leveled and azimuth adjusted separately.
SP10, ...... DIY Linear tonearm, ......Stanton 881s with D3000 stylus, .....BHL phono,.........Pass B1,
MODULUS 86 power amps x4,.............Active line level OX,......... bi-amped OB speakers with Mark Audio Alpair 12P
DIY linear tonearmHide this!Advertise here!
Linear tracking tonearm vs. Pivoting tonearm Don Nebel Analogue Source 5 31st May 2015 03:55 AM
Another DIY Tonearm johnmarkp Analogue Source 0 21st April 2008 11:07 PM
my DIY Turntables and DIY tonearm Roger Waters Analogue Source 57 22nd January 2008 06:05 PM
Magnetic suspension linear-tracking tonearm? Shaun Analogue Source 5 4th June 2003 10:21 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
