DIY linear tonearm
DIY linear tonearm
Old 16th March 2019, 09:56 AM   #2851
nocdplz is offline nocdplz
nocdplz's Avatar
Thanks Niffy: finger crossing.
Being used to work on metals, the carbon fiber (and bakelite) needed much more attention than expected. From the first Casey I knew the points that require maximum precision, but here everything is much smaller and lighter. The weights now are halved and the Vert. mass should be near to the Hor. mass (I love the pivoted ones, you know). We'll see if pen tips bearings will work better than the previous ball bearings: certainly need even more alignment accuracy.
I hope to be able to do the first tests in 2 - 3 weekends.
TT bearing: you complained about your ears, me of the eyes that are no more those of the past, so my doubts for making your system decently. Dealing instead with a "traditional" bearing and making it directly connected to the platter-spindle I would find all the noise into the cartridge. Experience already done.
The current idea is to do something dimensionally rigid, but capable to absorb separately the different resonances (disc tracing and bearing). The interface of the two system is just that thin red disk in the middle. Maybe a silicone mat (those used for oven), or sorbothane, or whatever fascinating brands the devil suggests...
carlo
mat - no mat (attachments) Difficult task, even with a good clamp; if you put a strong light in the back, you'll see it appearing somewhere under the disc. Trying something like # 2817 needs just a 1 mm cardboard donut and your clamp. Then trow it away, or make it better
Old 16th March 2019, 01:15 PM   #2852
Coolerooney is offline Coolerooney
Hmm
On the blanks for a platter:
Checked out a record presser- he can supply me with 50 blanks for 250 euro
They would make them after a normal run, so same material spec- reflection minimized
Further on the platter material discussion: how do mats figure in the equation, as it would change the materials etc etc
Best,
Coolerooney
Old 16th March 2019, 04:23 PM   #2853
niffy is offline niffy  England
Hi Carlo,
The mat-no mat issue. My recent work to reduce runout was sparked off by two things. First off is that the top of my platter is exactly at eye level from my listening position. The slight wobble of the platter was more noticeable from this viewing angle. The second thing was discussing bearings with you. I also have a window right behind the turntable. The light from the window combined with my viewing angle makes any gaps readily apparent. On occasional records I can see a slim sliver of light between the platter and record that extends about a centimetres at most from the edge. On the vast majority of records there is no light visible at all. As I mentioned before the clamp flattens most records so well it makes an air tight seal that keeps them pressed to the platter even after the clamp is removed.
When I was making the platter and before I had broken the surface it was transparent. I clamped a damp record to the platter and viewed it from beneath. The moisture on the record made it clear where the record was in contact with the platter. The record made good solid contact all the way from the edge to about a centimetre from the run out groove. This means that the entire playing surface of most records is in contact with the platter. The record only breaks contact for the last bit of the run out groove where it slopes up towards the spindle. The only way to improve this would be to add a peripheral clamp.
Niffy
Old 16th March 2019, 05:36 PM   #2854
Hi Coolerooney,
If the blanks are entirely flat and have a smooth shiny surface they could be made to work. If a stack of the blanks are pressed firmly together so all the air is forced from between them they will tend to stick together. This could be the basis of a laminated platter. The impedance of each lamina will be the same and they will be in intimate contact with each other. There will be a very small reflection of a compression wave at each interface. As the wave passes through the stack there will be multiple small reflections, each being partially reflected again and again. This could act to soften the intensity of reflection by defusing it. A laminate of this type will also likely have a higher level of damping than a single layer of the same thickness though it will have lower overall rigidity. It is possible that a laminated platter of this type could actually have advantages.
A layer of pvc glue of some variety spread of sprayed over the outside edge would help to keep the stack together and prevent air from getting between the lamina. 50 blank records could make a single platter 80 to 100mm thick or several more manageable ones. My brain is still leaning towards a solid platter but a laminated one is intriguing.
I would guess that your bullet proof glass is probably polycarbonate. It should be possible to cut this with a router using standard bits. It could make a good base section to go under a laminated vinyl top platter.
Niffy
Old 16th March 2019, 07:30 PM   #2855
super10018 is offline super10018  United States
Niffy,
I used a small hammer to hit the middle of brass sheet to make reassessed area.
The bearing of SME 20 is grounded and the spindle sits on a steel ball. I got the inspiration from Benz LPs cartridge. The motor of Benz LPs sits on solid brass. In the process of building my linear arms, I tried many shims made with different material to see how it affected sound. Brass is one of my favorites. My other favorites are carbon fiber, 2024 aluminum, magnesium. Brass mat is natural extension of my knowledge for material.
Does the brass mat reduce static? It is a tricky question to answer. I used have a lot of statics in my room under certain weather conditions sometimes. I could hear low pops noise while I was taking records off the platter and thought to get an anti-static fan to reduce statics. But it never happens since I installed the brass mat. So, I assume it works. At beginning, I used copper conduct tapes to cover the carbon fiber mat. It did reduce static as well. However, I prefer brass for its sound.
Jim
Old 19th March 2019, 02:43 PM   #2856
nocdplz's Avatar
Hi Niffy, i'm trying to better understand your clamp system (drawing according to your description, hopefully), because the idea of avoiding the machining of the acrylic platter attracts me a lot: everything is possible in this world, but to make the recess without a big lathe seems rather complex.
As you said, pushing the disk against the recess can raise the outer edge (bad idea, quote) but, considering that the clamp pushes to the center perhaps it is enough to give a small raised support on the outside and let it do his job, with much less force. Currently my cardboard gadget works fine on my old Lux TT, but maybe diying a new TT it can be improved quite simply.
Of course using a linear TA we have to consider that small tapering when leveling.
carlo
Old 19th March 2019, 04:16 PM   #2857
hottattoo is offline hottattoo  United States
My Oracle Delphi Mk2 turntable has a unique clamping system using a screw down clamp and a small convex "button" along with a semi sticky, sorbothane type mat. The clamp would force the outer edge of the label and outward down to make contact with the mat. The only problem is you could cause small cracks around the spindle hole buy using too much force on the clamp. I threaded my spindle to use a similar method but more precisely made. Unfortunately, vinyl records are not perfect in any dimension so we have to figure out how to deal with the minor variations.
Old 19th March 2019, 07:49 PM   #2858
Due to irregularity of records, it is almost impossible to flatten records by just relying on clamp only. This is why I use an outer ring. A well designed vacuum suction platter such as Air Force One is of course the best.
Old 20th March 2019, 11:55 AM   #2859
Hi Carlo,
Your picture of my clamping system is close to what I actually have. The raised section in the centre of the platter is more of a smooth dome than the cone that you show. Your picture shows the clamp contacting the record outside of the label area. This would cause the cartridge to hit the clamp on the runout groove. The label section is about 100mm diameter and the clamp only 75mm. The clamp is entirely within the label area. The idea of the reflex clamp is that it bows the record downwards onto the platter, your diagram shows the record remaining flat. The cross section or the record that you are using appears exaggerated. Get out an actual record and look at the changes in thickness, they are quite subtle. The downwards bow of the record will be mainly in the thicker label area. The thinner playing area bows back upwards to keep the entire playing area in contact with the platter.
Tapering the surface of the platter will have a similar effect, the surface of the platter will be a concave cone. (I mentioned exploiting this as part of my record centering idea) The down sides of tapering the platter are that in order to adequately flatten the record the tapper would have to be quite severe. This would result in a noticeable variation in VTA across the record and an azimuth misalignment. The azimuth can be corrected easily enough if the arm has this adjustment. Creating the taper accurately would require the use of a lathe if using a bare platter or a profiled mat. A less severe taper can be used if combined with a Reflex clamp or peripheral clamp.
I used a router to cut the recess for the lower part of the Reflex clamp. This was one of the easier parts of making the platter.
Hi Joe,
I used quite a lot of force with my clamp and have never seen any damage to the vinyl itself, definitely not any cracks. With some records with particularly shiny labels the clamp can leave slight marks. The dome in the centre of my platter is very gentle with no edges as you would get using something like a washer. It starts horizontal and flush with the platter and curves smoothly up to the spindle where it is again horizontal. The dome rises 1.2mm. This is designed to stress the vinyl as little as possible whilst giving the maximum flattening. Designing the clamp was one of the first things I did when starting on my tonearm design. I wanted to know what level of warps the arm was going to have to deal with before I started designing it.
Hi Jim,
The reflex clamp will eliminate all the warps on most records and force the vinyl into intimate contact with the platter across its entire playing surface. The addition of a peripheral clamp or vacuum hold down would have little or no effect on these records. Most of the records that a reflex clamp cannot completely flatten will be by the addition of a peripheral clamp. A vacuum hold down system will not have any real advantage on all but a very tiny number of records but is probably the ultimate record flattening system.
On my deck a peripheral clamp would have to be exceptionally well balanced or any advantage in reducing warps would be lost to increased runout. The addition of a vacuum system would compromise the whole way my deck works and would almost certainly lower its sound quality.
My clamp and low level of runout results in records that run so flat that I doubt that additional clamping would offer any advantages except for that occasional record.
As I believe that the clamp is more a part of the arm than of the deck at least we are getting a bit more back on topic.
Niffy
Old 20th March 2019, 02:57 PM   #2860
nocdplz's Avatar
Niffy, thanks for the useful clarifications; that sketch was just a scheme, made using the Riia section which exaggerates the proportions to highlight that disks are not flat, and normally without a recess may remain floating. Even the edge is important and uses a tapering to slide the stylus into the first groove.
The 1mm tapering generates just an angle of 0.35 , but it is more than enough to flatten the warps of my disks (I try to keep them well): the idea was of making a 0.5mm aluminum disk resting on an 1mm outer ring, and then glue it by pushing at the center. But your system is much easier, and I think I'll try to copy it.
I have a router used only to make the hole (only one, I love Full-range) in my speakers: I think I'll have to do a lot of practice to be able to do a precision work on plexy ...
carlo
I read that cast plexiglass often has no uniform thickness: did you have to level it?
DIY linear tonearmHide this!Advertise here!
Linear tracking tonearm vs. Pivoting tonearm Don Nebel Analogue Source 5 31st May 2015 03:55 AM
Another DIY Tonearm johnmarkp Analogue Source 0 21st April 2008 11:07 PM
my DIY Turntables and DIY tonearm Roger Waters Analogue Source 57 22nd January 2008 06:05 PM
Magnetic suspension linear-tracking tonearm? Shaun Analogue Source 5 4th June 2003 10:21 PM
Copyright ©1999-2019 diyAudio
