Hagerman Bugle 2
Hagerman Bugle 2
Old 19th February 2019, 03:09 AM   #151
sv62 is offline sv62  Canada
I did the swap of the L/R cables and the louder channel followed. I'm using a new project tt and a low end phono preamp. No issue with an imbalance audio before until I tested the bugle2 after completing the asembly.
Old 19th February 2019, 03:12 AM   #152
6L6 is offline 6L6  United States
6L6's Avatar
Hagerman Bugle 2
If, for instance, the Left channel was louder, and then you swapped the cartridge leads (from the turntable to the Bugle) and the Right channel was now louder, It's not the Bugle.
Old 27th May 2019, 12:17 PM   #153
Wellerman is offline Wellerman
What would be quieter (hiss-wise )for 60dB gain, a Bugle 2/3 @ 60dB or Bugle 2/3 @ 40dB + Piccolo2 @ 20dB?
Old 27th May 2019, 12:19 PM   #154
6L6's Avatar
Hagerman Bugle 2
Probably the headamp plus the phonostage, but that's not cast in stone. The Bugle has pretty nice noise performance.
I'm a huge fan of transformers with low output MC...
Old 27th May 2019, 08:15 PM   #155
No experience with transformers. AFAIK they are not as flexible though. A few dipswitches and the Piccolo 2 and you can use it for almost any cartridge.
Old 28th May 2019, 06:58 AM   #156
andyr is offline andyr  Australia
That's an interesting question, Wellerman.
I can't see why the 60dB Bugle would be any noisier than a 40dB Bugle + 20dB Piccolo ... and you get the advantage that the signal then passes through:
* 1 less interconnect, and
* 2 less RCA plug/socket connections.
Like you (and unlike 6L6), I am not a fan of SUTs - as they do not give the load flexibility that can be obtained by having the phono cable plug directly into the RCA sockets on a phono stage or head amp.
Andy
Old 8th June 2019, 06:12 PM   #157
According to Jim Hagerman himself Piccolo 2 + Bugle 2 would have less hiss, but Bugle 2 on its own is no slouch.
Another question: what would be the best capacitor for the RC-filters on the rails of the Bugle (220 uF) and Piccolo (100 uF)? Low ESR types like Panasonic FM? Do they influence the sound and should I go for "for audio" types like Nichicon KZ or Silmic II? Or is the "for audio"-thing mostly hype? Is X7R ceramic a good choice for the 100nF decoupling caps?
Old 8th June 2019, 11:04 PM   #158
Yes, IMO, power rail filter caps do influence the sound - I personally use Nichicon on all my builds.
I suggest you need to use a 'good-sounding' film cap for signal decoupling. So I typically use RelCap RTX.
Andy
Hagerman Bugle 2Hide this!Advertise here!
FS: Hagerman Bugle w/Power Supply craigtone Swap Meet 0 1st December 2012 11:36 PM
New hagerman bugle+power-supply boards... tweakk Swap Meet 0 29th July 2010 04:43 PM
WTB: Completed Hagerman Bugle phono pre. Big_Bill Swap Meet 1 26th May 2010 02:46 PM
Anyone Building A Hagerman Bugle? atw58 Analogue Source 5 14th April 2008 01:50 AM
Hagerman Tech. 'bugle' phono preamp lgreen Analogue Source 6 13th March 2007 03:46 PM
Copyright ©1999-2019 diyAudio
