Bearing Lubrication
Bearing Lubrication
Old 30th May 2013, 11:24 PM   #1
SuperTuck is offline SuperTuck  New Zealand
Default Bearing Lubrication
With an inverted TT bearing, how is the lubrication maintained.
With a standard bearing sitting in a pot of oil and a screw cut up the shaft or sleeve, its obvious how the shaft can maintain lubrication.
Old 31st May 2013, 04:16 AM   #2
w_oswald is offline w_oswald  Canada
Good question - I've wondered about that myself. Unless someone has experience otherwise, I'd be inclined to try using an appropriate grease. That generally is quite resistant to flowing under the force of gravity, and it is - after all - a relatively low-speed application.
Old 31st May 2013, 08:00 AM   #3
Straight Tracker is offline Straight Tracker  United States
Default Hello All
Not knowing any better, this is how I would do it.
Sincerely,
Ralf
Old 31st May 2013, 08:51 AM   #4
Thanks Straight tracker,
Yes thats what I would have done, had I had a simple bearing.
Unfortunately I need a large structure so I can fit a magnetic bearing at the bottom, at least 4inch below the platter top.
I will probaby use a 19mm shaft (because its quite long, will be more stable) with two 19x19mm bronze bushes, so only have a point of contact at the top and bottom. I dont know how efficiant felt washers are at keeping oil present in the bearing, they were used alot back in the 50-60's.
Bearing LubricationHide this!Advertise here!
Lubrication of SONY KSS optical pick up with metal and plastic muff fonon Digital Source 4 20th March 2012 02:43 PM
Goldmund JVC motor lubrication marknoir Analogue Source 2 18th February 2012 12:46 PM
Ball-race arm-bearings - lubrication an absolute no-no? Aleksunder Analogue Source 11 22nd September 2007 08:07 AM
Rotel RCD970BX: CDM9 lubrication/replacement to cue skipping timestwo Digital Source 11 18th June 2007 05:41 AM
lubrication of platics Bas Digital Source 10 9th January 2003 02:27 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
