OPENAMP1 - MM phono preamp open project
Old 9th August 2018, 10:03 AM   #181
PMA is offline PMA  Europe
PMA's Avatar
Thank you both for the positive feedback. I am glad that the preamp works well and that you like it. IMO it shows that even with opamps we may get very good sound and profit from the buffered output.
Old 13th August 2018, 09:54 PM   #182
spaceistheplace is offline spaceistheplace
spaceistheplace's Avatar
Default OPENAMP1 - MM phono preamp open project
Originally Posted by PMA View Post
For those who might be interested, I have prepared an open project of the phono preamplifier for MM cartridge. It has very low noise and very low distortion. Gain is 40dB/1kHz. Output is capable to drive 50 ohm load, so one may directly connect headphones via 100 - 220 ohm pot. Please feel free to download documenation from
Preamplifier for MM cartridge
Link is dead in OP. Can you update to the new link here: Preamplifier for MM cartridge
(would be nice to have in the OP)
Are there Gerbers available for JGs MC head amp? Perhaps PSU?
The real aim of music is to co-ordinate the minds of the people into an intelligent reach for a better world and an intelligent approach to the living future.
Old 14th August 2018, 06:35 AM   #183
PMA's Avatar
Several years ago my pages were moved to my server, address is in my signature. You will find openamp there as well.
Pavel Macura audiopage
Old 17th August 2018, 01:32 PM   #184
chat72 is offline chat72
Is it possible to modify riaa a bit. I think lifting around 100-2000hz or suppress treble around 5k-10k would suite my need. I am using standard value.
Thank
C.S.
Old 21st August 2018, 08:20 PM   #185
kamis is offline kamis  Serbia
Is it necessary to reduce value of power rail capacitors ( 470 micro) if shunt voltage regulator is connected close to preamp ?
Old 22nd August 2018, 09:55 AM   #186
I have no problem using 470uf with Salas shunt.
Old 23rd August 2018, 03:18 AM   #187
nezbleu is offline nezbleu  Canada
nezbleu's Avatar
Agreed I used a Salas BiB shunt regulator for my Openamp-1 with no issues and no modifications of the circuit. I connected the regulator to the phono board with a short length of shielded twisted pair, about 6 inches as I recall. (and yes I mean 2 regulators, one positive one negative. The voltages were rock solid.)
"In the world of commerce and finance it is thought quite remarkable if a man is both clever and honest." -- Demosthenes
OPENAMP1 - MM phono preamp open projectHide this!Advertise here!
Swiss Physics model 5 preamp MM phono input Eric Tang Analogue Source 14 21st June 2015 06:02 PM
Best rbb transistor, for MM phono preamp claudio Solid State 27 31st January 2013 12:58 AM
MM phono preamp with accu and solarcells Koifarm Analogue Source 5 4th November 2012 09:32 AM
Phono preamp mm cartier20002000 Analogue Source 8 27th November 2007 03:17 AM
LT1028 mm phono preamp? miziq Analogue Source 9 27th April 2007 05:10 AM
Copyright ©1999-2019 diyAudio
