Paradise Builders
Paradise Builders
Old 21st July 2019, 05:17 PM   #4211
Pete2 is offline Pete2
Thank you Jan ,
I think the cap in 105/205 position is a cheap electrolytic but I'll check your suggestion.
Probably I will start will pulling out 103/104 as I have not many parts around here , I'm going to Europe in a week , while there I'll buy some more .
Is getting bit late so I will try to check all this sometime during the week
Thank you
Old 21st July 2019, 05:43 PM   #4212
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Where in Europe are you going to?
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 21st July 2019, 07:51 PM   #4213
Jan
Few days in Ireland/Cork then Poland/Krakow and possibly Germany/Berlin(Wildau)
Old 21st July 2019, 07:51 PM   #4214
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Paradise Builders
If your friend has used polymer caps in the shunt that will be the culprit, 25v 100if cap
Old 21st July 2019, 07:52 PM   #4215
These caps are electrolytic , looks cheap
Old 21st July 2019, 07:56 PM   #4216
jan.didden's Avatar
Nice trip. Have fun.
Jan
Old 21st July 2019, 08:06 PM   #4217
big chunk is work related ,
I'll report back when I make some progress
thank you Jan
Old 22nd July 2019, 08:35 PM   #4218
I managed to find different 10uF cap , left it running for an hour and best I can trigger is this :
I'm using 60MHz probe and 100MHz scope , would be beneficial to get better probe -100MHz?
Old 22nd July 2019, 08:44 PM   #4219
for the above div= 0.05us , 5mV
Old 22nd July 2019, 09:00 PM   #4220
jan.didden's Avatar
This looks more like a measurement artifact to me. Some sweep trigger ringing. You probably see that too with everything shut off.
Jan
Paradise BuildersHide this!Advertise here!
Paradise phono stage hesener Group Buys 1392 24th March 2019 09:39 AM
DIY Paradise - Any good to buy from? gingerpimp0069 Vendor's Bazaar 7 21st June 2007 02:07 PM
DIY Paradise Charlize Jolojl Swap Meet 7 7th December 2006 06:42 AM
Diy Paradise! alexmoose Tubes / Valves 3 24th July 2006 04:37 AM
Another way to paradise ? Bernhard Pass Labs 3 8th August 2003 10:19 PM
Copyright ©1999-2019 diyAudio
