Cheap oscilloscope for setting up a Technics SP-10
Old 28th June 2011, 06:54 AM   #21
Mooly's Avatar
Hi John... pity about the bid, fingers crossed for the next one eh
just try tweaking that 78 rpm pot to satisfy your curiosity A good trick with presets is to measure the voltage on the wiper (but be consistent using the same DC range and measuring points). Write it down and then tweak... and you can always then put it back where it was.
Old 28th June 2011, 08:28 AM   #22
mikemac is offline mikemac  Australia
mikemac's Avatar
Is the sp-10 a different board than all the other Technics/Panasonic dd turntables, like the 1200"etc? I think i would just buy a new board! They can be had for $50 bucks.
Tho if i had an excuse to buy an Oscilloscope..........
"my names Mike Peterson, But most folks call me Bull"
Old 28th June 2011, 07:47 PM   #23
johnm is offline johnm  United Kingdom
johnm's Avatar
Mooly: I think I'll leave it for the time being - at least until I've recapped the control board (which is the only one left to recap). Spending 100+ for something I may well only use once - trying to kick the DIY habit! - would be a bit of a waste. Hopefully when I recap that last board that'll sort out the very (and it really is a big 'very') slight juddering of the strobe on the 78rpm setting, without needing to adjust any pots. There's only two pots for the three speeds, so it wouldn't be a simple case of just being able to nudge one to sort out the one speed, alas.
Mike: They're completely different boards with the SP-10 Mk.II being quite a bit more complex than the SL1200/1210s.
Cheap oscilloscope for setting up a Technics SP-10Hide this!Advertise here!
Technics SP 10 Speed Problems rollinr Analogue Source 29 27th October 2017 09:05 AM
Improved PSU for Technics SL1210 MK2 and SP 10 MK2 (and others) beetle Analogue Source 21 19th January 2010 11:25 PM
Technics SP-10 speed problems Stefanoo Analogue Source 3 17th August 2008 10:05 PM
Technics SP-10 MkI Start/Stop problem jgc31746 Analogue Source 2 13th April 2007 10:40 AM
Technics SP-10 MKII pitch control peterb Analogue Source 6 28th March 2004 01:29 PM
Copyright ©1999-2019 diyAudio
