Puresound P10 RIAA
Puresound P10 RIAA
Old 13th June 2011, 10:39 AM   #21
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Only needs to solder the output caps & the suggested RIAA mods, also I need to drill the RIAA chassis & connecte all
Old 13th June 2011, 10:59 AM   #22
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Puresound P10 RIAA
Ok
So my first sugestion is:
R17 = 38K9 // 478K = 35973 r
C9//C8 = 2.7nF // 106pF // 180pF = 2.986pF (and because of miller // 38pF = 3.024nF)
C7 = 6nF // 2.2nF // 640pF = 8.84nF
Old 13th June 2011, 06:30 PM   #23
SY could be B+ 150V for both tubes? because I want to use only one Salas HV shunt reg for both tubes & the designer Mr. Gay (PureSound) told me that I can do it without change any component.
Old 13th June 2011, 06:37 PM   #24
On Hiatus
SY's Avatar
Puresound P10 RIAA
Your distortion will certainly be higher with a lower B+. Overload margins will be lower. Why not use 230V as a compromise between the two voltages called out on the schematic? Or bite the bullet and build two regulators?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 13th June 2011, 06:51 PM   #25
I don't want to use anode resistors for each tube: I prefer connect direct the Salas HV reg also I have only one Bartolucci transformer 150VAC secondary & one 10H Bartolucci choke (both are expensive: best quality), the RIAA is for a friend who has spent a lot of money & I don't want to ask more money.
What about if I reduce E88CC to 80V with a anode resistor? could you tell me the value if OK?
Old 13th June 2011, 07:00 PM   #26
On Hiatus
SY's Avatar
Puresound P10 RIAA
If you connect the plates directly to the regulator, your playback will be quite silent.
A 240V isolation transformer more than big enough to run that preamp should cost less than 20 euro.
Old 13th June 2011, 07:27 PM   #27
That's a good idea, arrives later for my friend but for me can be a cheap alternative for my 26 preamp, could you suggest some 240V isolation transformer with high quality to buy in Europe?
Old 13th June 2011, 07:30 PM   #28
Default Pics
Only for fun a couple of pics
Old 13th June 2011, 08:24 PM   #29
nhinstruments
RCruz's Avatar
Puresound P10 RIAA
Nice case... what is your source ?
Are you going to put the TX inside also ?
Old 13th June 2011, 09:08 PM   #30
Source to buy the case is:
modushop.biz
No, the tx & choke in a separate box (Puresound P10)
Puresound P10 RIAAHide this!Advertise here!
Acurus P10 in need of help boy412 Analogue Source 15 6th July 2010 06:01 PM
P10 EL70eN now shipping... planet10 Planet 10 hifi 0 17th November 2009 07:45 AM
Puresound A30 aquapiranha Swap Meet 0 9th January 2009 08:35 PM
Teac P10 transport radar Digital Source 0 21st May 2007 07:56 AM
Puresound widget? raintalk Multi-Way 1 14th December 2005 02:03 AM
Copyright ©1999-2019 diyAudio
