I have some 2SK170bl lying around and want to make an amp for my Denon DL103 to go into the MM input on my Copland. I have an SUT but wanted to try SS. I'm looking for a simple circuit that has the option of gain switching to allow for lower output MCs further down my MC road.
Anyone know of a cct diag, preverably running off a 9v supply.
No RIAA eq needed.
No RIAA eq needed.
There:
http://www.diyaudio.com/forums/power-supplies/184068-psu-rc-multistage-filtering-2.html#post2486919
Tony suggests having a minimum of 5Vdc difference between input-output on LM 317.
It is my observation in praxis that this holds true for fixed voltage 3 leg regulators as well. It garantees specified regulation action from the chip.
This 5V difference is hidden in many of the performance curves supplied by the manufacturers of the voltage regulators.
Salas thanks for providing this schematic.
George
George
You can have it working safely with up to 25Vdc input.
http://www.alldatasheet.com/datasheet-pdf/pdf/231443/TI/UA7800.html
With the current you are drawing in this application, temperature rise would not be an issue.
George
George
Dear Salas
With 35V in and 9Vout, Vdrop is 26V. This, times 15mA makes a 390mW.
Still not too high, but 35Vin is according to some manufacturers above from what they allow.
But I won't argue with you, because the nice schematic you provided before, is ideal for building a pre to be installed just behind the cartridge on the headshell.
I would like to try this.
But I am lucking the Fets.
Do you know any source in Athens?
George
George
- Analogue Source
- 2SK170 BL MC step up amp
