High end turntables and sound reproduction - few questions
Did an experiment. I kept my new belt in kerosene for 10 to 15 minutes. Belt size increased about 1 inch. Took out the belt let it dry for 6/7 hrs. Belt returned to normal size but with 2/3 mm more length. Record speed also shows normal speed. (better than previously noted). Will check it again.
(As I got my belt cheap I took the risk of dipping it in kerosene, so would advice to take extra precaution and necessary care with this materials. As I think belt can be rendered useless too with such materials.)
