Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Thread Tools |
#2821 |
This is what came with my order from Audio-Silente. It fits in the bottom of my motor beneath the spindle. The spindle has the original 2mm bearing in it. What is the diameter supposed to be and where would I get one?
I wasn't sure what to call it but I am talking about the motor. Not the main platter spindle housing. Still probably using the wrong words for what I am trying to describe. Sorry. m |
#2822 |
If this is for the motor it's the right size, your last post was somewhat lacking in context. It fits in a recess in the bottom of the bearing housing. I might have misunderstood.. LOL
It should be retained by the bearing assembly if assembled correctly? Can you take some pictures of the assembly as you put it back together? The way the spring washer is installed is important, but it is so long since I did it I no longer remember the orientation. It is fairly obvious if oriented incorrectly..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine |
#2823 | |
td124motor Hope this helps. |
#2824 |
I put my motor back together and ran it for 30 hours. Everything sounded good with the stethoscope. The motor was pretty hot but I did not get a reading on exactly how hot. I picked up a Digital Laser Tachometer to help me out. It read 1733.3rpm at the motor pulley with no belt attached. I read a post on AK that 1740rpm was considered a good build.
I then reinstalled the platter to take a look at the strobe. Results are not that good. ![]() This TT is serial# 3427. The resistance on the coils are: Black to Red = 84 and 83 Black to Green = 264.4 and 264.8 Black to Yellow = 55.3 and 54.8 Are these acceptable? I do have a new set of coils. I just thought it would be good practice to try to get as much as I can out of the original coils. Would the new coils solve my problems? I do reach speed eventually and it remains steady once there. It just seems like there is not enough torque to get things going. The other problem may be my motor bushings. I soaked them in 20w oil but I did not go through the procedure of heating them up. They are from Audio-Silente and I believe arrive pre loaded so i did not bother. But maybe I should? I am sure my motor build could be improved upon but I still think there is something I am missing. I am also in the process of reading this entire thread again. I took notes the last time but I must have missed something. I have regularly visited The Analog Dept. for years. First, for my TD-160 and now the TD-124. I don't think it is lack of information. It is knowledge, experience and execution. ![]() ![]() |
#2825 |
Also Kevinkr,
I will take pictures as I move forward. I did open up my motor after the most recent attempt and the thrust pad was right where it belongs. I just read somewhere else to put a dab of grease underneath to keep it down. My motor spindle does move up and down a bit when you pull on it. I thought that while upside down maybe the pad could jiggle around in there. m |
#2826 | |
I actually have that page open as well. I think I may need a day or two away from this TT. m |
#2827 |
Well here we go. Post #991. Old coils = 1380-1400rpm. So there is still a bit of room to improve.
![]() m |
#2828 |
I am also thinking that this cheap Tachometer is lying to me.
![]() m |
#2829 |
Does anyone know where to source motor bearing plate rivets in US? Thanks
#2830 |
Mcmaster.com has them. Small machine screws work also.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Need help with Phono Cartridge for Thorens TD-166-MKII | sonictonicmusic | Analogue Source | 20 | 6th May 2016 08:44 PM |
Thorens TD-124 newbie | neil_kaye | Analogue Source | 6 | 17th March 2008 03:44 AM |
Thorens TD-125 MKII Parts | needlenose | Analogue Source | 9 | 12th March 2005 11:08 PM |
Transformer for Thorens TD-166 MKII | Peter Menting | Analogue Source | 5 | 30th August 2003 07:15 PM |
Thorens TD 124 MKII question | louis | Analogue Source | 3 | 2nd July 2003 04:27 AM |
New To Site? | Need Help? |
