Old 31st January 2019, 07:08 AM   #1981
lcsaszar is offline lcsaszar  Hungary
Default Pantograph
Has the Pantograph principle ever been used for LT tonearms? I mean moving along a linear guiding rail copied to the radial travel of the stylus.
Old 31st January 2019, 07:31 AM   #1982
nocdplz is offline nocdplz
nocdplz's Avatar
Interesting idea Icsaszar - but have you ever used one?
My 2 cents: the parallelogram copies, in small or large, what you draw with the pencil, the lines on which the tracking force is applied (multiplied or demultiplied according to the magnification ratio).
Here the force is exerted by the stylus, so - frictions apart - you may just have a small or large copy of his path: if instead you want that the stylus follows a line, the force must be applied on the guide line = that means to use a servo. And feedback?
carlo
Old 31st January 2019, 08:09 AM   #1983
No, I've never created a tonearm, just an idea. I see the major problem is four bearings instead of one, and the vertical movement is not easily provided.
Old 31st January 2019, 09:07 AM   #1984
nocdplz's Avatar
More than a problem of bearings, imho it's a problem of vectors: the stylus drag is orthogonal to the guide and therefore completely unusable - the side force breaks down according to the angles of the levers, so on guide point is available only a fraction.
But the idea merits to be further investigated
c
I meant a common drawing pantograph: the effort to make it work in magnification is so great that is normally used simply by reporting reference points
Old 17th July 2019, 11:59 AM   #1985
Consty is offline Consty  Romania
Default Klaudio tonearm FreeCAD model
For those interested in the Klaudio tonearm, I have created in FreeCAD 0.18 a functional model (attached). In order to see it at work, you must copy/paste the contents of the attached Kla_python.txt in FreeCAD's Python console.
Besides the ruby jewel bearings, the toughest challenge for a normal DIYer is machining the Gaussian bell shaped guide
But where there's a will, there's a way...
Old 17th July 2019, 03:39 PM   #1986
directdriver is offline directdriver  United States
directdriver's Avatar
Default Klaudio
Originally Posted by diyrayk View Post
5-17-2018, 6:40PM Post#1773
I will put on my flame-proof suit and proclaim that all (with maybe one possible exception, the Klaudio) PLT tonearms will skate and, if a particular PLT doesn’t appear to exhibit skating tendencies, it’s likely because the linkage pivots are saddled with excessive friction. This is the bargain that you make with the devil when you go with a PLT design. I myself consider the negative side-effects of skating and bad bearings to be worse than tracking error.
Since Consty brought up the Klaudio tonearm, I was skeptical of it being skating free...
A recent video titled "Klaudio KD-ARM-xx10/12 Anti-Drifting Steps," shows that it can skate.
The video even says "light drifting of the headshell is acceptable" after showing steps of adjustment.
Old 17th July 2019, 05:00 PM   #1987
Dear directdriver, IMHO I can't see the tonearm skating. In fact I see it... anti-skating I mean its slight tendency to move from the label to the middle of the record, tamed after a proper setup of the parallelism of the two arms using that Allen key.
Since no Klaudio video shows us the needle running on a rotating grooveless record face, we cannot say whether this geometry exhibits skating or not.
Old 17th July 2019, 05:29 PM   #1988
Since the arm is floating with zero tracking force, isn't that similar to playing it on a blank groove record? And if it's skating free, why would it drifts in the first place? Will this pass Ray's string test?
The fact that it has a tendency to drift without fine tuning, which seems to be a form of anti-skating or anti-anti-skating adjustment, suggests, at least to me, skating force exists. Maybe the drifting is caused by bearing friction or uneven tensioning of the dual pivots? The fact that it rests in the middle reminds me of the Thales Easy arm that the single tangential point is set in the middle groove so the arm gets to overhang on the outside groove and underhang on the inside groove.
I'll let the more perceptive members here to settle this one.
Old 17th July 2019, 05:54 PM   #1989
Absolutely not. A tonearm balanced at zero VTF with zero anti-skating setting (if this setting exists in the makeup of the tonearm) should stay exactly where it's placed by hand, no matter if that place is near the record rim, the middle or at the runout groove.
The inward skating force appears as a result of the friction between the stylus and the surface it is running on, be it a record groove or a flat surface of a one sided record. That's why some purists in terms of anti-skating adjusting say that the flat record face test is not relevant enough due to the higher skating forces implied by the much higher friction faced by the stylus plowing the grooves. So, no needle contact = no skating
Old 17th July 2019, 06:15 PM   #1990
That drift appears when the arm is floating, meaning no contact between stylus and groove.
Gliding for 90° - mechanical linear tonearms: no airpump, no servo directdriver Analogue Source 33 3rd April 2016 11:40 PM
Angling of ports and/or drivers? Dave McReeferson Full Range 11 27th March 2012 07:45 PM
String suspension vs. uni pivot or gimball tonearms nghiep Analogue Source 26 13th August 2011 04:27 AM
Angling drivers left and right in a vertical line-array???? ozziozzi Multi-Way 12 16th January 2009 04:23 AM
Need Amp For 90-0-90 V DC Drafance007 Solid State 15 12th October 2003 08:03 PM
Copyright ©1999-2019 diyAudio
