Linn "LINTO" MC Preamp Schematic without SMPS - Schematic for SMPS wanted
Old 21st October 2012, 08:01 PM   #31
tvi is offline tvi  Australia
tvi's Avatar
Can't help with schematic but this might be of interest.
WO9965135 NOISE SUPPRESSION SYSTEM FOR A POWER SUPPLY. LINN PROD LTD
The small part of ignorance that we arrange and classify we give the name of knowledge.
Ambrose Bierce
Old 8th February 2014, 02:35 PM   #32
kkwan18 is offline kkwan18  Wales
Is it possible by replacing the switchmode power supple with a transformer?
Old 8th February 2014, 04:31 PM   #33
niamex is offline niamex  Bulgaria
Definitively it is a right step ahead IMHO. Will post here the whole story of my mod I am very cslose to finalize-long story At the moment it is singing like a bird.
Cheers
Old 8th February 2014, 06:30 PM   #34
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
No. You need additional a rectifier bridge or four pieces of high speed diodes, capacitors and voltage regulator, both for positive and negative voltage rail. Instead a serial regulator I would prefer a parallel regulator. And instead one supply for both channels I would prefer two monaural power supplies to optimize the GND management.
Originally Posted by tiefbassuebertr View Post
schematic for "LINTO" SMPS still needed
no one here who has now opened this module and drawn the schematic diagram?
Old 8th February 2014, 06:53 PM   #35
Fully agree but I have just replaced the diodes with hyper fast ones paralleled with 0.1 uF and simply delivered the required voltage by an R-core trafo - works fine so far.
Old 20th February 2014, 03:28 PM   #36
plasmarepairs is offline plasmarepairs
Thanks for all the info posted here. Our unit was tripping power light then dead. fault caused in our case by C19 on the AVS PWB.
Old 28th May 2014, 08:21 AM   #37
willis202 is offline willis202
hi Niamex,
my Kairn SMP is also broken, could you please tell me the transformer each pin output voltage? so I can find a fitted a normal toroidal transformer. thanks.
Old 29th May 2014, 12:52 PM   #38
andyr is offline andyr  Australia
I need the schematic diagram from the switch mode power supply. Who can help?
From the experiment I have just done, you should build an analogue (regulated) PS which supplies the same DC voltage as the Linto SMPS does ... it will sound better!
(A SMPS is used for cost & size reasons - not SQ!)
Andy
Old 31st May 2014, 08:52 AM   #39
Originally Posted by willis202 View Post
hi Niamex,
Sorry I am late, it was long time ago and I do not remember exactly the voltages but you can see the photos and judge what to do - definitely new hyper fast soft recovering diodes /Fairchild/ and an R-core trafo.
Ignat
Old 4th June 2014, 02:12 AM   #40
Thanks for the useful help, but you how to fix the trafo, I saw you just put it above the PCB, It will not cause a short-ciruit? Thanks again.
Linn "LINTO" MC Preamp Schematic without SMPS - Schematic for SMPS wantedHide this!Advertise here!
Schematic wanted for VTL Preamp "Maximal" tiefbassuebertr Tubes / Valves 22 30th November 2014 02:04 PM
Ultimate MC RIAA phono pre for "Blue Oasis" (Win Research Group) schematic? tiefbassuebertr Analogue Source 6 31st August 2014 03:49 PM
Digital Audio Cross Selector "D.C.A.S. 7-3" from DIGITRONA - schematic wanted tiefbassuebertr Digital Source 2 4th August 2012 11:47 AM
31 Band Equalizer "the t.eq" "TQ-60" schematic wanted tiefbassuebertr Solid State 2 29th March 2010 04:45 PM
Schematic - B & K MC-101 Sonata (Pro-MC-10) Preamp dtm1962 Solid State 0 13th June 2006 08:46 PM
Copyright ©1999-2019 diyAudio
