There is another way to make a direct coupled input. It is fully differential and does not have the noise disadvantage of a long tail pair. The RIAA could then follow with a differential Opamp as I did in my Phonostage article in Linear Audio.
In order to avoid confusion :
The attached image shows a differential amp or differential pair
(if driven differentially as indicated), corresponding to post 11202.
A long tailed pair is a particular example of another differential amp.
With equal bias etc both have the same gain and the same noise.
Well, it is symmetrical.
The top looks the same the other way around.
Anyway, you find what we published in the Zion thread.
When we started that thread we wanted to make a ready made stage that you can buy.
It got so incredibly complex in the end that we gave up on that idea.
