MPP
MPP
Old 20th February 2020, 01:50 AM   #11091
Destroyer OS is offline Destroyer OS  United States
Destroyer OS's Avatar
MPP
Did you have a low inductance load right on the output of the capacitor multiplier? If not you should add a capacitor with a little bit of ESR but low inductance real close to it.
Old 20th February 2020, 01:55 AM   #11092
jackinnj is offline jackinnj  United States
jackinnj's Avatar
MPP
Please, always snub a cap multiplier.
Any inductance after a regulator or cap-multiplier is like putting on dirty underwear after a refreshing morning shower.
Originally Posted by Joachim Gerhard View Post
Zetex
another reason to have Horowitz & Hill, The Art of Electronics V3 on your bookshelf!
Old 20th February 2020, 02:02 AM   #11093
keantoken is online now keantoken  United States
keantoken's Avatar
A good standard troubleshooting method is to record the voltage at each transistor/chip pin, then it should be easy to tell if something is wrong. You can do the same with AC readings to see where the signal stops or noise begins.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 20th February 2020, 08:01 AM   #11094
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
MPP
Zetex
Would you please suggest a model ?
RC
Old 20th February 2020, 03:06 PM   #11095
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
ZTX851, 951
Old 21st February 2020, 08:18 PM   #11096
This time I have luck. The circuit in post 11082 worked right away.
The only difference is that I use a conventional plus-minus supply.
That has a disadvantage. Input and output offset has to be trimmed.
I simply made the two supply voltages as similar as a could with a simple trimmer.
There is is a bit of hum. That partly comes from the mains transformer that is in board and partly from the PSSR that is not that great.
I have a solution for this that I will try now.
File Type: jpg 4F96F3C9-132F-46C6-A3C0-8F38A1DEDA62.jpg (500.4 KB, 204 views)
File Type: jpg 32BF0813-628B-44E3-A929-79DCBE9225CC.jpg (726.6 KB, 200 views)
Old 21st February 2020, 08:21 PM   #11097
Sorry 11083.
Old 22nd February 2020, 12:05 PM   #11098
Building constant current sources for better PSRR and less distortion.
File Type: jpg E19786CA-0DB6-4F13-9EE0-E8965949ACC3.jpg (741.2 KB, 186 views)
Old 22nd February 2020, 01:06 PM   #11099
It works
File Type: jpg 5C64C172-D072-4BA8-A6F5-98262C2CB161.jpg (519.4 KB, 179 views)
Old 22nd February 2020, 01:54 PM   #11100
nhinstruments
RCruz's Avatar
MPP
ZTX851, 951
Very low Vcesat.... that means low Rcesat... very good
Do you know if they make a dual NPN/NPN and dual PNP/PNP version ?
RC
MPPHide this!Advertise here!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
