Valve Itch phono
Valve Itch phono
Thread Tools
Old 23rd November 2021, 11:28 PM   #3461
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Valve Itch phono
Originally Posted by merlin el mago View Post
Salas it's normal more gain using the SHURE V15 type III or have I to look for the need of more gain in other place?
With 3.5mV output you should not need more than 43dB in any case. Many MM preamps have 37dB for 5mV carts as standard. 40dB for 3.5mV equals them. The Itch has at least 43dB on healthy tubes. Either the V15 has gone weak (usually its rubber suspension) or it needs more load capacitance to liven up or you need gain elsewhere in the system's chain.
Old 25th November 2021, 11:37 AM   #3462
merlin el mago is offline merlin el mago  Catalonia
merlin el mago's Avatar
Thanks Salas, I suspected the same. I will try 1st with more load capacitance. The tubes are ok. The Itch it's connected to 26 preamp with Sic bias, Bartola hybrid Mu-follower, 15K-300R OPT & Dave Slage AVC.
Old 25th November 2021, 05:46 PM   #3463
Salas's Avatar
Valve Itch phono
Is the power amp's voltage gain and the speakers sensitivity loud enough as well?
Old 26th November 2021, 11:44 AM   #3464
Power amp Mono block Erno Borbely 75W RMS Class A, speakers DIY 86dB or less because the passives filter.
I'm using the 26 with OPT to listen with headphones HD600
Old Today, 02:35 PM   #3465
Salas what about if I use a bypass capacitor at R9 330R?
Old Today, 07:28 PM   #3466
Salas's Avatar
Valve Itch phono
It would not add anything much. 0.3dB or so. Full Mu stage gain is already achieved. Its a Mu follower.
  Reply to this post
Valve Itch phonoHide this!Advertise here!
Thread Tools
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 27th September 2008 12:49 AM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 09:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 05:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 03:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 03:12 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
