Valve Itch phono
Valve Itch phono
Old 31st March 2020, 11:58 AM   #3381
merlin el mago is offline merlin el mago  Europe
merlin el mago's Avatar
What's the best SQ?
Old 31st March 2020, 03:34 PM   #3382
zz1969 is offline zz1969  Russian Federation
The power supply in the latest version is much simpler to save the space (CLC). I believe this resulted in a bit muddier bass. In the first version it was cLCLC. But the difference is very subtle I would say. Maybe as Salas said there were/are some parasitic capacitances.
I haven't done any testing yet btw.
Old 31st March 2020, 06:20 PM   #3383
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Valve Itch phono
There is always parasitic capacitance in layout styles but I wonder how different between each p2p build and the specific board.
It maybe changes the input capacitance or second stage's Miller effect a bit. If there is measurable difference in the response between p2p and board builds it can be adjusted by tweaking C3 value.
But that is in the same area of how much treble preference also. Other changes between builds like in the PSU configuration may bring differences of course.
Valve Itch phonoHide this!Advertise here!
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 26th September 2008 11:49 PM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 08:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 04:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 02:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
