Valve Itch phono
Valve Itch phono
Old 18th September 2018, 02:16 PM   #3131
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Valve Itch phono
This is how it simulates for response with anti-Riaa at the input, C4 0.1u, R8 820k, C6 2.2u, and a 20k output load (a dcb1 buffer pre with its 20k pot for instance)
Old 18th September 2018, 02:19 PM   #3132
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Thanks Salas, please could you simulate C4 0.1uF C6 3.9uF & 100K output load?
Old 18th September 2018, 02:23 PM   #3133
Salas's Avatar
Valve Itch phono
Here it is
Old 18th September 2018, 02:26 PM   #3134
Looks like the same, right?
Old 26th September 2018, 08:13 PM   #3135
Still some hum but using scope don't see any AC oscillation. I connected the mu metal sheet covering the tube sockets to chassis ground waiting to lower the hum.
Old 27th September 2018, 05:45 PM   #3136
Lowered the hum but still some hum when volume pot starting to 1 to 2 o'clok. It seems needs more screening.
Old 28th September 2018, 11:15 AM   #3137
Link to youtube YouTube
Old 28th September 2018, 12:03 PM   #3138
Scope don't show ripple no other strange artifacts.
Old 28th September 2018, 03:46 PM   #3139
Salas's Avatar
Valve Itch phono
Maybe its a ground loop when connected to the system. Because the buzz in the video clip sounds strong enough and should have been captured by the scope.
Old 29th September 2018, 07:56 PM   #3140
Now I'm using a volume with switch ladder resistor of 100K so the source always see 100K, i'ts in a small box between the Itch and the preamp: could be the source of ground loop?
Valve Itch phonoHide this!Advertise here!
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 26th September 2008 11:49 PM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 08:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 04:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 02:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
