Valve Itch phono
Valve Itch phono
Old 13th September 2018, 01:35 PM   #3101
merlin el mago is offline merlin el mago
merlin el mago's Avatar
If increase volume increase the hum.
Old 13th September 2018, 01:46 PM   #3102
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Valve Itch phono
Didn't have in the past but it recently developed? If so I would start from tubes swap or screening or moving away if other gear transformer was introduced nearby and the hum went up or undo some sensitive modification
Old 14th September 2018, 11:02 AM   #3103
Thanks for answer Salas, always was the hum. No other gear introduced nearby. I will try swapping tubes if hum not goes away I will try screening the tubes.
Old 15th September 2018, 02:16 PM   #3104
Salas could be the Belton micalex sockets some people said go for teflon? Or the 6SN7 to 7N7 adaptor?
Old 15th September 2018, 02:48 PM   #3105
Salas's Avatar
Valve Itch phono
If the contacts are clean inside them and they achieve good mechanical lock I would not think that the choice of bases can be a factor for background noise. Adapter maybe can expose more if its barrel is not grounded, but a swap from 7N7 back to 6SN7 direct would tell.
Old 15th September 2018, 04:27 PM   #3106
Hum gone swapping the 7N7 tubes with adapters included
Salas worth the change for teflon sockets to improve SQ?
Old 15th September 2018, 04:55 PM   #3107
Salas's Avatar
Valve Itch phono
Don't know, haven't used such high quality sockets. Beyond the good insulation material they seem to have very nice machined copper gold plated contacts also and that alone can be a plus when combined with well cleaned and chemicals treated tube pins (Cramolin/Deoxit).
Old 15th September 2018, 05:06 PM   #3108
Thanks again Salas.
Old 16th September 2018, 09:52 AM   #3109
Question Anti RIAA for Itch
Salas could I use this anti-RIAA to measure the Itch RIAA accuracy?
Component values
Ideal Actual Alternative
R1 883k 909k 910k
R2 75k 78.7k 75k
C1 3.6n 3.3n 3.3n
C2 - 180p 270p
C3 1n 680p 1n
C4 - 270p -
R3 0 1.48k 1 - 1.5k
Old 16th September 2018, 05:51 PM   #3110
Salas's Avatar
Valve Itch phono
Most of those Anti-Riaa circuits are theoretically accurate but to make a practically accurate one with ready to buy parts I think Bonsai's approach is best: http://hifisonix.com/wordpress/wp-co...verse-RIAA.pdf
Valve Itch phonoHide this!Advertise here!
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 26th September 2008 11:49 PM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 08:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 04:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 02:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
