Valve Itch phono
Valve Itch phono
Old 28th July 2017, 11:09 AM   #3031
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Vin 12,49 & 12,63VDC
Old 28th July 2017, 11:45 AM   #3032
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Valve Itch phono
Are the regs heating up too much now?
Old 28th July 2017, 11:56 AM   #3033
Yes too hot but still can touch the heat sinks. Now solid as a rock 6,1VDC (when jumped I forgot to connect B+).
Old 28th July 2017, 11:57 AM   #3034
Salas's Avatar
Valve Itch phono
Because they both now see the HV voltage divider heater lift. Put bigger sinks...
Old 28th July 2017, 11:58 AM   #3035
Yes, I will look for.
Old 28th July 2017, 12:04 PM   #3036
Salas's Avatar
Valve Itch phono
Lets hope it will work as noiseless as before with no SQ loss also since common winding and heater voltage reference for both reg branches now.
Old 28th July 2017, 03:40 PM   #3037
The two heater windings are separate!!!
Old 28th July 2017, 03:52 PM   #3038
With this one still too hot. http://es.farnell.com/webapp/wcs/sto...&storeId=10176
Old 28th July 2017, 04:21 PM   #3039
What thermal resistance is necessary?
Old 28th July 2017, 06:46 PM   #3040
Salas's Avatar
Valve Itch phono
Originally Posted by merlin el mago View Post
The tx have two secondaries more of 5,2V AC 3 A each so can reach together 11,8V AC?
I left the Lundahl heaters or I come back to the two 12V 3A?
You planned to first try put two windings in series to make a higher one I thought.
Valve Itch phonoHide this!Advertise here!
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 27th September 2008 12:49 AM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 09:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 05:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 03:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 03:12 PM
