Valve Itch phono
Valve Itch phono
Old 18th April 2015, 10:04 PM   #2051
merlin el mago is offline merlin el mago
merlin el mago's Avatar
What's the expected bias, the voltage across the diode?
Old 18th April 2015, 11:38 PM   #2052
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Valve Itch phono
Some voltage across the diode, yes. Since the current there is low it won't be full 0.7V that is why we may use IR LED or two diodes if the tube sample don't go very little mV across open input.
Old 19th April 2015, 05:33 AM   #2053
stajo is offline stajo  Sweden
Valve Itch phono
I think a well choosen IR is by far more linear then 1N4148 at those currents. A bypass, like a low noice 100k from top anode to diode anode might get the current up to linear levels, and maybe to levels where grid current stops with the strong bias level of one diode.
Edit. Maybe not on second thought. It looks hopelessly nonlinear up to some 50 mA. http://www.nxp.com/documents/data_sh...148_1N4448.pdf
Would a low noice 1k-2k be worse noisewise then the unlinear effect of the diode to the sound?
Old 19th April 2015, 12:56 PM   #2054
Salas's Avatar
Valve Itch phono
V1.2 depicts an IR for those reasons you mention, if not having one and the diode is not working well but using a resistor, better bypass it with a large value electrolytic 1000uF 6.3V to filter its noise
Old 19th April 2015, 01:11 PM   #2055
Valve Itch phono
Yes. Depending on where the grid current starts its a call between harder biasing for more signal current with a resistor or rectifyer diode and less bias current and presumably lower noice with an IR diod.
Old 19th April 2015, 01:58 PM   #2056
Salas's Avatar
Valve Itch phono
This tube we use has good GM to small Ik ratio presenting low hiss plus very quiet mechanically, and it got slowly recognized for phono input use these days, obscure if not used at all for that back when used in the Itch, so its worth solving for Ig carefully by sample basis. They generally differ by sample when it comes to grid current negative bias threshold, but its relatively low always.
Old 19th April 2015, 02:10 PM   #2057
Valve Itch phono
I have some boxes, and one of them is OTK-marked (military tested). Will measure them up.
Old 19th April 2015, 05:51 PM   #2058
Valve Itch phono
I guess Merlins problem might be just grid current. A SUT should be able to take more DC then a PUP-coil.
Old 19th April 2015, 07:30 PM   #2059
Valve Itch phono
I made an attempt to measure grid-anode and grid-cathode capacistance after running a few 6N2P's in the AVO. Since a difference of 1 pF can matter quite alot, especially concerning that Cmiller= C(1+Af), important for the second stage and riaa comp values it was interesting to see that Cga and Cgk measurments differed quite a bit on how I held the crocs. If I added a socket on the tube it increased by nearly double. Then I tested just with the crocs distance and got a difference of like 2 pF just by holding them near or far away from each other. A lession for when doing interconnection cabling, yes indeed. Croc/cabling distance is far more important then tube sample differences concerning grid capacistance.
Measures made with DER EE DE-5000
Old 19th April 2015, 07:43 PM   #2060
Salas's Avatar
Valve Itch phono
The method used for determining Miller is comparing -3dB upper limit in a common cathode circuit between two different source resistances (virtually series to the grid) then calculating back from the measured Av. It takes gen & scope.
With the LCR you could roughly say a type has more parasitic than another when steady for wires, but to be sure of the absolute figure is quite tricky.
Valve Itch phonoHide this!Advertise here!
Got the build itch again. 80w kt88 itsmejto Tubes / Valves 44 26th September 2008 11:49 PM
valve phono stage wanted for mc brobarrie Swap Meet 1 13th August 2007 08:17 PM
Basic DIY Valve Phono Stage matthew2456 Tubes / Valves 5 29th March 2007 04:11 AM
Phono pre, valve or jfet lndm Analogue Source 7 4th April 2006 02:11 PM
phono preamp design for c3m postie valve fergs1 Tubes / Valves 1 29th May 2005 02:12 PM
