Phonoclone 3
Phonoclone 3
Thread Tools
Old 26th February 2021, 06:29 AM   #751
Phloodpants is offline Phloodpants
Actually, a slight tweak makes it easier to get parts in the exact value, or within tolerance for hand-picking.
75K - Widely available
10.9K - Not available, but on the low side of 1% tolerance 11K resistor.
29.2nF - Not available, but well within 5% tolerance 30nF
10nF - Widely available.
Chris Hoppe
http://hoppesbrain.com
Old 26th February 2021, 12:58 PM   #752
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
Phonoclone 3
You could split the gain difference by reducing R3,4 (in your figure above) from 2.2k to 1k ohms, which increases the gain of the second stage 6dB, leaving just 8 to make up for in the first stage.
RJM Audio | phonoclone.com
Old 26th February 2021, 06:04 PM   #753
Thanks! Yeah, I'm trying to avoid loading up the output too much. The OP27 will swing +/-10V into 600 ohms, but I want to be nicer to it than that. The knee of the curve for output swing vs. load is around 1K. Distortion remains low anyway.
So here's a happy medium, 1.21K.
And this is the preamp itself. I built the power supply into the boards themselves, and it's picking up a little hum, which I think will go away with the new feedback values.
Chris Hoppe
Old 27th February 2021, 10:22 AM   #754
Richard Murdey
rjm's Avatar
Phonoclone 3
Hi Chris,
While it's a compact an efficient layout, the close proximity means there is a risk of noise coupling between the AC wires and the audio signals, as well as from the magnetic fields of the power transformer.
I hope you can manage to get the hum down to manageable levels.
RM
File Type: jpg wp-16143659110853006920527348182889.jpg (139.6 KB, 78 views)
Old 27th February 2021, 05:10 PM   #755
Yeah, the plan is to move the power supply to another chassis if it still hums, but I wanted to give it a shot without needing a separate chassis.
The hum isn't too bad now, actually.
Chris Hoppe
  Reply to this post
Phonoclone 3Hide this!Advertise here!
Thread Tools
WTB phonoclone boards c.d.s. Swap Meet 1 8th June 2008 09:04 PM
My take on the phonoclone Onvinyl Analogue Source 34 27th March 2007 02:11 PM
WTB: Phonoclone boards KT Swap Meet 0 20th February 2007 06:48 AM
Phonoclone Update rjm Analogue Source 70 6th July 2005 01:42 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
