Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Thread Tools |
#18731 | |
Thanks! |
#18732 |
diyAudio Chief Moderator
30VA-50VA each
#18733 |
Thanks Salas!
How do I wire the 32 V primaries of the 2 transformers to one IEC (230 V)? Usually one of the primaries is tagged with a tape at the end (indicating the inner winding?). Thanks! |
#18734 |
32V can't be primaries but secondaries. Primaries should be 115V each. Depends on each brand. Could be connecting two tagged or specifically colored ones together and the side ones to the mains. But better look it up at the manufacturer's website.
#18735 |
Thanks Salas!
Luckily, I did not mix up primaries and secondaries in real life ![]() The background of my question was if it is necessary to use 2 fuses with 2 transformers as suggested in this thread: Wiring up two trafos to one IEC socket. Which slow blow fuse(s) should I use (230 V), 1.25 A? Thanks! |
#18736 |
Its not necessary to use individual primary fuses by electrical safety code. In case you want to, you should not skip a central fuse. In other words 2.5A in the IEC socket and 1.25A before each 50VA transformer for USA. Cut those figures to nearest 1/2 available amperage values for Europe and other 230V countries. All such fuses should be time lag (T) type. What we call slow blow.
#18737 |
The ultra is using PF5102 fets? I can't find a data sheet that specifies the noise figure, any clues?
#18739 |
Thanks!
#18740 |
Hello Salas and Tea-Bag, I finished my preamp with BA2018 line stage boards stacked for Balanced operation with the UFSP with shunt regulators in the same chassis. The power supplies for the display/ relay input /volume control/remote, has a 250vac 30A relay to turn on the power supply for the BA2018 line stages.
The UFSP has a remote power supply with umbilical cord, the shunt regulators are mounted vertical with the home made heat sinks 10mm below the vents in the steel chassis. After 3 hours of operation, the inside of the enclosure stayed the same temperature. It is dead quite on all of the inputs, the UFSP I've adjusted and played HO MM, LO MC, HO MC. After a month of playing, time to move it into the main system. Thank you both for all your help with this project! |
Thread Tools | |
New To Site? | Need Help? |
