Simplistic NJFET RIAA
Thread Tools
Old 9th January 2021, 06:08 PM   #18721
6L6 is online now 6L6  United States
6L6's Avatar
F5 has lower gain because of different feedback resistors than F5T.
Old 9th January 2021, 06:20 PM   #18722
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
(100R//100R)/10R=5x (+1 non inverting config)=6x
20Log(6)=15.56dB
Originally Posted by IDM View Post
My F5 is not the turbo version so I understand the gain to be 15.5dB.
Old 11th January 2021, 06:33 PM   #18723
IDM is offline IDM  United Kingdom
Hi Salas,
I took your advice and bought an Aneng AN8008. It seems somewhat better than the meter I was using before. Latest calculated gain is 60.3db. So slightly short of 62db but once again it sounds about right.
I was wondering about adding gain into the DCG3 and have asked the question on its thread.
Thanks,
Ian
Old 11th January 2021, 07:16 PM   #18724
Salas's Avatar
Ian hi,
Nice with getting the DMM. It should be helpful for reliable AC mV range readings you are interested in. I just did a confirmation check. See photo. About the DCG3 higher gain option I replied in its thread.
Old 18th January 2021, 07:31 PM   #18725
SKA76 is offline SKA76
50VA is humongous for the job.
What would be the minimum for this job: could two 20VA transformers with 32 V secondaries work in a 230 V environment? Or better one more powerful transformer with 32 + 32 V secondaries?
Thanks!
Old 18th January 2021, 07:47 PM   #18726
Salas's Avatar
Typically both solutions would work. Its about CCS consumption loading, no time break, and full bridge rectification steals 40% of a transformer's AC current rating.
I have seen 30VA frame transformer becoming substantially warm under such conditions.
Old 18th January 2021, 08:30 PM   #18727
Thanks Salas!
In other words better borderline humongous using one or two 50VA transformers with 32 V secondaries than letting the transformers sweat
Old 19th January 2021, 08:24 AM   #18728
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
One more UFSP finished.
As I had already the previous blue boards, this one is better.
More detail, less noise, more depth.
Of course these comments are not very objectives, as I used different and little bit better components, I feel that this new design is a worthwhile upgrade.
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 19th January 2021, 05:40 PM   #18729
Salas's Avatar
Originally Posted by SKA76 View Post
Thanks Salas!
50VA Antek which is very much used by American builders has magnetic shield that their lesser VA models don't have is another reason why usually recommending 50VA
Old 19th January 2021, 05:44 PM   #18730
Salas's Avatar
Congratulations for your build. It looks by now well established from enough reports, including yours, that the black UFSP redesign also offers little more subjective performance beyond gain set up flexibility with DIP switches which was the main update goal.
Simplistic NJFET RIAAHide this!Advertise here!
Thread Tools
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
