Simplistic NJFET RIAA
Old Yesterday, 05:18 PM   #18051
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by SRMcGee View Post
What would you suggest be checked next?
Many thanks,
Scott
Voltage across Q6 & Q5 (drain to source each) on both channels
Old Yesterday, 06:16 PM   #18052
SRMcGee is offline SRMcGee  United States
SRMcGee's Avatar
Salas:
Q5: 7.33v R, 7.40v L
Q6: 12.82v R, 12.87v L
Scott
Good decisions come from experience. Experience comes from making bad decisions. (Mark Twain)
also, Everyone has a plan, till they get punched in the mouth. (Mike Tyson)
Old Yesterday, 06:53 PM   #18053
Salas's Avatar
Not suspicious readings. Some RCA terminal discontinuity possible? Buzz them to board connections with the DMM? C3 C4 discontinuity possible? Try other any quality C3 C4 or swaps between channels to see what happens?
Old Yesterday, 09:47 PM   #18054
SRMcGee's Avatar
Salas:
I expect the problem is something incredibly simple but I am oblivious to it. The input and output RCAs have been tested, C3 and C4 check out just fine and I've reflowed all of the relevant solder points, all to no effect. I cannot find a point in the right channel that is inconsistent with the left channel.
I'll take a couple of days away from this problem and try again after the weekend, hopefully with refreshed eyes.
WTF?
Scott
Old Yesterday, 10:02 PM   #18055
Salas's Avatar
It normally takes a generator and a scope. To feed it sinewave signal and probe the circuit's path until spotting where it stops.
Old Yesterday, 10:13 PM   #18056
Salas's Avatar
Using same color signal wires and accidentally swapped hot for cold at some spot could be such a trap for instance
Simplistic NJFET RIAAHide this!Advertise here!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
