Simplistic NJFET RIAA
Old 15th July 2019, 11:51 AM   #17531
aheck is offline aheck  United States
Originally Posted by Salas View Post
@Salas, Thanks much for your reply. It only makes sense that these two designs should work together. I'll be boning up on the available literature while I wait on my order. I'm very++ excited.
Old 15th July 2019, 01:05 PM   #17532
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Wishing you a successful DCG3 build then.
BTW what about your FSP? Did you fix it?
Old 16th July 2019, 12:53 PM   #17533
Would you believe it self-healed? I had tried and tested it for days. I left it idle because of a myriad of family bad luck and used an Advent unit I had recently purchased on the cheap for it's MM stage with a Stanton 881 NOS I got my grubby little hands on. Anyway, when I tried your stage again, there were no anomalies, so I hooked up the Denon 103 and gave it a try with flawless results. Coulda' knocked me down. And as good as that Advent and Stanton sounded, that LOMC sounds better in every regard. Thanks again for your patience and help.
Old 16th July 2019, 04:27 PM   #17534
Salas's Avatar
Some intermittent point in a cable or in a part's leg or a cold solder joint maybe (?). Keep an eye on it. Anyways, for now happy end.
Simplistic NJFET RIAAHide this!Advertise here!
Copyright ©1999-2019 diyAudio
