Simplistic NJFET RIAA
Old 10th March 2019, 08:35 PM   #17401
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Turn DMM's mode to Hz as you measure that, if it will display 120Hz then its surely mainly about rectification ripple. Haven't got a target figure noted in my files. But its low raw ripple level what you measured anyway.
Old 12th March 2019, 08:56 PM   #17402
Hikari1 is offline Hikari1  United States
Salas: for the MC step up in the original Nfet phono do I need to change any resistor values (R1?) when using 8.2mA jfets?
File Type: png Screen Shot 2019-03-12 at 1.54.45 PM.png (447.2 KB, 173 views)
Old 12th March 2019, 10:08 PM   #17403
Salas's Avatar
Keep it the same. There will be inconsequentially small difference in the DC drop across R1 and maybe one extra dB of gain.
Old 14th March 2019, 07:17 PM   #17404
exw9 is offline exw9  United States
I just finished my build and switched it on. One channel I get all the LED's and the other channel the 4 on the side never come on. I am overwhelmed where to start, are there common issues that would cause this?
Also, my Raw PSU is putting out about 27V DC. Is that enough? I saw in the biasing that it is looking for 35V
Old 14th March 2019, 08:32 PM   #17405
Salas's Avatar
Hi
You need 42-50V RAW DC level to start with
Old 14th March 2019, 09:13 PM   #17406
Salas's Avatar
Get a 32V+32V toroidal (four wire). One secondary to each RAW DC board's input.
Old 14th March 2019, 09:42 PM   #17407
perfect, thank you! I will get that installed and then see what the board LED's are doing.
Old 14th March 2019, 09:51 PM   #17408
Salas's Avatar
We see about that next. Maybe one LED is in reverse, or somewhere around them a voltage isn't right, something. If one channel is alright you can compare the bad one's voltages at points.
Old Yesterday, 08:05 PM   #17409
I built the MC step up. Sounds very, very good. But it's very sensitive to placement. It must be a meter away from my big class A amp for best results. But it is not in a metal box yet.
Running off batteries for now. Works as advertised.
Anybody compared this against a transformer SUT?
Old Yesterday, 10:06 PM   #17410
Salas's Avatar
Good screening for sensitive circuits in traditional diy fashion comes with dead bug style construction on a raw board's copper back housed in a tin can.
I prefer direct high gain input where hum and buzz problems can be solved without a step up transformer.
Simplistic NJFET RIAAHide this!Advertise here!
Copyright ©1999-2019 diyAudio
