Simplistic NJFET RIAA
Old 4th October 2018, 11:43 AM   #17261
le´flu is offline le´flu  Germany
thanks for your rating. I think i´ll try the itch.
Is there a later Version or ist revision 1.2 the newest one?
Valve Itch phono
And the PSU ist still as in #3 ?
Greetings
Old 4th October 2018, 11:53 AM   #17262
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
There's no more than 1.2 & yes PSU is #3. Good luck in making it as it takes 100% handcraft and let us know how it went in its thread. Be careful with high voltage, but you already know that.
Old 4th October 2018, 01:07 PM   #17263
Hi Salas,
thanks. As it is noch my first valve-Project i´m not afraid of high voltages.
And no problem with handcraft - valve-projects need less parts ;-)
What gain can be expected from the Ref. 1,2Version without the SUT?
Old 4th October 2018, 08:12 PM   #17264
Salas's Avatar
Says on the schematic 45dB after the SUT meaning the circuit's gain alone
Old Today, 12:43 PM   #17265
MASantos is offline MASantos  Portugal
I got myself a rega RP8 with dynavector XX2mk2 and a rega aria phono stage.
I will be changing my simplistic for MC duties and then try to compare them side by side.
My amplifier has the means for input level matching so I'll be able to do some rudimentary A/B testing.
Would a splitter RCA cable be a problem when connecting the cartridge to 2 different phono stages? Would the loading resistors in one influence the circuit in the other?
Old Today, 01:32 PM   #17266
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Just think about that arrangement. The loading resistors will be parallel.
I would avoid that. Even a switch after the cartridge.
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old Today, 02:13 PM   #17267
anatech is offline anatech  Canada
anatech's Avatar
Hi vgeorge,
I agree completely! The wiring to the cartridge shouldn't be messed with at all. It's hard enough to get the resistance and load capacitance right. Adding anything to that signal will probably turn out to be a disaster.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Simplistic NJFET RIAAHide this!Advertise here!
