Lightspeed Attenuator a new passive preamp
Old 29th September 2019, 08:02 PM   #5701
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
Originally Posted by Puffin View Post
For some inexplicable reason I seem to have much less control over the volume. It gets loud very quickly which it didn't do before. Do these things go off? Is it likely to an LDR or PS issue? I am using exactly the same PS as previously.
I take it the system is exactly the same, nothing has changed to vary the system gain?
If so and the difference you get (gets loud very quickly) is happening in both channels, then the dual 100kohm log pot has gone faulty, replace it.
Cheers George
File Type: jpg Lightspeed Attenuator MkII Circuit Diagram.jpg (99.8 KB, 271 views)
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 29th September 2019, 09:19 PM   #5702
Puffin is offline Puffin  United Kingdom
Hi George, that was my thoughts as I couldn't think of anything else. Everything else in the system is as was. Thanks for your help.
Old 29th September 2019, 11:10 PM   #5703
georgehifi's Avatar
Get the bigger 24mm >.25w one.
Cheers George
Old 30th September 2019, 03:14 AM   #5704
Eric is offline Eric  United States
Eric's Avatar
Sounds like either the wiper on the pot or the surface that the wiper rides on has oxidized. It can be cleaned with some electronics cleaner spray, but it will only oxidize again. As George indicated, I'd replace it with one that is of higher quality.
DIY Theater, Aleph-X Amps, LDR based BA-3 pre, B1 Korg, Pearl II, modified SL-1200 TT, F4, M2, Aleph-J, MoFo, a40, ACAs, FHXL & TB 1772 speakers
Old 12th October 2019, 10:24 AM   #5705
Hi George, me again. I seem to remember that someone some years ago posted a schematic for a balanced LA. Not sure if this was you or if you are aware of it?
Old 12th October 2019, 08:15 PM   #5706
georgehifi's Avatar
Don't have it anymore, as they don't stay calibrated over time, just use xlr to rca adapters, if you only have xlr on your components.
Cheers George
Old 12th October 2019, 10:44 PM   #5707
Ok, thanks for replying.
Old 16th October 2019, 06:20 PM   #5708
Rodolphek6 is offline Rodolphek6
Hello George
I am always delighted since 2 years of the lightspeed it orders 2 blocks formerly with tubes of 1984 with RF7 lll.
I'm going to buy Klipsch Belle, but they're a little light on the bass, that's where I need your advice: how can I connect a subwoofer in parallel?
Yours sincerely
Rodolphe
Lightspeed Attenuator a new passive preampHide this!Advertise here!
Copyright ©1999-2019 diyAudio
