Lightspeed Attenuator a new passive preamp
Old 12th August 2016, 07:00 AM   #5571
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
It will be messy but can be done, to replace each single gang pot you'll need two NSL32SR2's.
Then you could probably use the existing pot's it has to be the voltage controller for the led section of the NSL32SR2.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 12th August 2016, 02:21 PM   #5572
noviygera is offline noviygera  United States
Do you think 8 LDRs in in the signal path would be more transparent in terms of audio than 8 "blue velvet" pots?
Is there any additional control hardware that Needs to fit into the mixer to use LDRs In addition to actual LDRs and pots to control them?
Herman
Old 12th August 2016, 09:46 PM   #5573
georgehifi's Avatar
Does a single sound better than one, general consensus of Lightspeed owners is yes.
Cheers George
Old 12th August 2016, 11:17 PM   #5574
Chris Daly is offline Chris Daly  Australia
Herman
What you are not being provided answer on post after post, is that mixers invariably
have balanced circuits, but also cater for some unbalanced inputs as well
ie the rear panel of the link you provided - ( although not the mixer you intend to convert ) - shows XLR connections. An overview of the fundamental differences is here:
http://www.perreaux.com/blog/2012/2/...balanced-audio
One way to do balanced with LDR's involves achieving a signal side double L pad, and careful matching of not only Left to Right, but also then Hot to Cold. When done correctly It works well !
I suggest though to involve firstly sourcing the schematic for the mixer you actually intend to convert.
Old 13th August 2016, 06:15 AM   #5575
R.I.P.
What he is not telling you is that it is the connections that are balanced.
The system is balanced impedance and that impedance is referring to the connections.
Make the inputs and outputs balanced. Use balanced connections, Use balanced complimentary equipment.
Inside the mixer it is far easier to convert all the bal inputs to unbalanced. process all the signals inside as unbalanced. Then convert the signals back to balanced ready for the balanced impedance connections.
Look at B.Putzeys' balanced volume control to see this in operation. Bal input > bal 1st stage > bal to unbal 2nd stage > unbalanced vol pot > unbal to bal output stage > bal output.
regards Andrew T.
Old 14th August 2016, 03:09 PM   #5576
By the way it would be fair to mention that I do not have a design and schematic. I'd love to work with someone who can help design and tune this project to my needs.
Can anyone suggest a capable designer who would work on a mixer project for money?
In this application I will use unbalanced inputs and balanced outputs.
Old 6th December 2016, 04:03 AM   #5577
dv187736 is offline dv187736
Just new in this thread though I've read the posts till p510. I'd like to build an SLA but the only LDR readily available locally is NSL32SR3. My questions may have been asked already but I'll ask anyway. Are the only reasons for not preferring the NSL32SR3:
- harder to get a matched pair/quad?
- issue with getting lowest resistance(?) that affect low volume listening?
Though it might be difficult, are there ways to go around these? Thanks in advance.
Old 11th December 2016, 11:11 AM   #5578
gianxdiy is offline gianxdiy  Italy
Hi guys, just a feedback:
mounted the second kit provided by Uriah on a Copland CSA-8.
I choosed 2way pot for 20k total impedance. Perfect balance tight, round and powerful bass, airy mids, more refined highs, stable and focused stage.
What can i say?
Many many thanks George and Uriah!!!
Old 11th December 2016, 06:20 PM   #5579
georgehifi's Avatar
You could parallel up the S3's to get a lower impedance, then matching up quad sets will become an even bigger headache.
Cheers George
Old 13th December 2016, 09:14 AM   #5580
Cheers George
Thanks, George, for the advice. Will take note of this should I go ahead with the SR3s.
Lightspeed Attenuator a new passive preampHide this!Advertise here!
Copyright ©1999-2019 diyAudio
