Lightspeed Attenuator a new passive preamp
Old 7th November 2015, 07:03 AM   #5511
kffern is offline kffern  Australia
I have found myself a set of udaileys matched LDRs.
Can someone advise me as to how I should select them in the circuit.
From the attached image should I use one from each pair for the the left and right series LDR and the remaining 2 for the shuntsas the image below? Or have I completely misunderstood this.
Thanks,
Kffern
Old 7th November 2015, 07:20 AM   #5512
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
[QUOTE=kffern;4508578]I have found myself a set of udaileys matched LDRs.
Thanks,
Kffern
These matched pairs.
The lowest ohmage matched pair should be used as the L&R shunts to get the lowest minimum volume
And the higher ohmage pair as the L&R series
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 7th November 2015, 09:21 AM   #5513
Thanks George,
So in my case #147 and 159 should be the L&R shunts and the 189,197 the series?
Are they so close it probably makes little difference?
I plan to buy a bunch and match someday....
Kffern
Old 7th November 2015, 10:27 AM   #5514
R.I.P.
What are the black figures (under the k values) telling us?
what about values for 10k and 5k?
regards Andrew T.
Old 7th November 2015, 01:00 PM   #5515
udailey is offline udailey  United States
147 and its match for series because at low volume it wont match as well in shunt.
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 7th November 2015, 01:03 PM   #5516
Youve got it right in the pic.
Old 14th November 2015, 06:38 AM   #5517
sugano is offline sugano  Hong Kong
Dear all,
I'm really interested in making the Lightspeed Attenuator. Can I possibly buy 4 matched 32SR2S' from someone who has spares? Hopefully quad matched instead of 2 pairs?
Thanks!
Peter
Old 14th November 2015, 06:53 PM   #5518
georgehifi's Avatar
Hi Peter, you can get them in Hong Kong get the $5 led tester I posted in the 1st post of this thread. Get a friend and yourself to buy 20 pieces from here, you'll get enough for two quad matched sets and sell the left overs ones.
Hong Kong Nsl-32sr2s, Hong Kong Nsl-32sr2s Manufacturers and Suppliers on Alibaba.com
Cheers George
Old 19th November 2015, 10:08 PM   #5519
thesavage is offline thesavage  Australia
Cheers George
Hi George,
I followed the link you supplied for the LDR's but they didn't have any in stock.
I managed to locate a different supplier but the model number is slightly different. Are they still suitable?
NSL-32SR2. - ADVANCED PHOTONIX - OPTOCOUPLER, RESISTIVE O/P | element14 Australia
Appreciate your assistance,
Tim
Old 19th November 2015, 10:28 PM   #5520
georgehifi's Avatar
Originally Posted by thesavage View Post
Hi George,
Tim
Yes Tim, they won't be as close to each other as the "S" version, so get another ten to get quad matching, you'll probably end up with 2 x quad matched sets so you could sell one set here.
Also the "S" version is typical 40ohms (on resistance) @20mA, so the "S" gives better attenuation at minimum level.
Where the "non S" does not specify (on resistance) @20mA, and can be a bit of pot luck, minimum level could be a bit loud for background music.
Cheers George
Lightspeed Attenuator a new passive preampHide this!Advertise here!
Copyright ©1999-2019 diyAudio
