Lightspeed Attenuator a new passive preamp
Old 28th July 2013, 02:18 PM   #5091
wapo54001 is offline wapo54001  United States
George, I went and looked at the data sheet for the sorted and unsorted versions. On consideration, I think I would agree with you if a) the objective is to build a Lightspeed-type device and b) it's true that the presort does somewhat match the devices before the end user does a final matching of sets of devices. For my purposes, I think the non-sorted version is the way to go.
I see that the sorted ones are pre-sorted into seven groups, with the difference between the groups being the individual LDR's resistance at 1ma. The groups range from 100~110 ohms at the low end to 181~200 ohms at the high end. Very importantly for me, they say up front that there is no way to specify which group you want when you order and no guarantee which group you'll get.
Otherwise, I see no difference between the SR2 and SR2S devices. Particularly, both the sorted and the non-sorted are guaranteed to meet 40 ohms at 20ma which, by the way, I find to be quite the exaggeration because a number of the ones I've tested don't meet that standard.
So, if all SR2 and SR2S devices theoretically meet the 40 ohm requirement, then the "sorted" designation only suggests that you will get some semblance of similarity in response between individuals in a batch and that has no value -- at least to me -- because there is no way to specify which level of resistance you want.
The non-sorted SR2 shows only a "typical" resistance of 140 ohms at 1ma, which is in the middle of the range and confirms that there will be devices of all resistances including devices at the better-to-excellent end of the range. If a user is going to custom sort them anyway, may as well pay a lower price. For me, that is especially true because if I wound up with a sorted batch with all the devices at the high end of the resistance at 1ma range, and all of the devices requiring at least a full 10ma to achieve 50 ohms and many did not meeting that requirement, I'd be pretty unhappy.
@jameshillj -- Some people with very high gain systems have complained that the Lightspeed does not turn the volume down far enough to listen at low levels. Also, you're right -- if you're controlling the LDRs with a PIC, it is very easy to include a "mute" capability. If the LDRs don't have adequate low resistance response, that won't work so well. Also, if you keep the volume position very low or in mute, you don't want to be passing 20ma of current through your LDR continuously because you run the risk of permanently changing the characteristic of the device.
If you select devices that produce low resistance at moderate to low current and then parallel them, you have a very low resistance capability with low current passing through the LDRs and can thus leave them at that setting for extended periods without damaging them.
Old 28th July 2013, 05:29 PM   #5092
Originally Posted by stajo View Post
I second that. A fully fool proof build description would be worth an arm and a leg.
From what I have learned so far, a "kit" version of this would be very difficult to produce because the beauty of the PIC-LDR relationship is that you can program the PIC to precisely match the characteristic of the LDR at any given level setting. You would have to program this relationship after building the kit, which means the kit builder would have to be able to not only build the hardware but also measure response and then program the PIC.
I suppose that it is not impossible -- the PIC possesses the computational horsepower to self-program itself with the proper connections and the proper programming but, if you want a no-compromise system with no extra connections to the audio path, it would have to be an intermittently available self-programming feature that works when music is not being played -- at first turn on or or command and then disconnected for music..
Old 29th July 2013, 12:06 AM   #5093
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
If one does not get down low enough with the resistance without overdriving the led's, then clients that have high gain high efficiency speaker such as horns, JBL's etc, then a common complaint is, for background music they can't get low enough volume. Also quad matching comes into it as well for a nice progressive logarithmic feel to the volume control.
Yes you can match up the sr32 for low impedance but you will have far more surplus ones that don't and are basically useless. You will have far less wastage from matching up sr32S units. And have better reliability, built in as most don't have to be overdriven to attain 40ohms
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 29th July 2013, 01:08 AM   #5094
georgehifi's Avatar
Here is a pic. The left one is a 32SR2S R2D batch no. and on the right is a 32SR2. Note the different ldr leg thickness, it is thicker on the "S" showing different manufacturing as well. When ever I order these I nearly always get the same batch no. Maybe one or two sneak in that are not, I just put them to the side for an order that does mate up with that batch no.
Cheers George
Old 29th July 2013, 02:29 AM   #5095
Cheers George
George, with the sorted version, how many LDRs on average would one need to acquire in order to come up with a matched quad like you have described as using in the production Lightspeed?
Old 29th July 2013, 03:33 AM   #5096
georgehifi's Avatar
Approx half as many as the 32SR2.
Cheers George
Old 29th July 2013, 05:48 AM   #5097
georgehifi's Avatar
And you can match them like I used to in the early days using this $10 led tester primitive but effective way, and measure the resistances with an ohm meter, just don't use the 50mA range.
Cheers George
Old 29th July 2013, 06:22 AM   #5098
georgehifi's Avatar
Or you can go to $20 for the more elaborate one.
Cheers George
Old 29th July 2013, 08:01 PM   #5099
A couple of things have come together to give me a new insight and I thought I’d pass it along for others to consider.
In re-reading the article about LEDs that I recently posted the URL for, I got reacquainted with LED characteristics and that information jelled with some other information I’ve acquired in a search for the appropriate capacitor to use in the control circuit for my LDRs.
First, LEDs are current-driven devices. The only way to control them with accuracy and consistency is by controlling the current that passes through them and not the voltage that is applied to them. Second, for LDR applications in audio, current must be controlled at a very fine level – on the order of one micro-amp. Third, in researching capacitors, I find that film capacitors have very low DC leakage but are typically only available in capacitances up to about 2uF. Electrolytic and tantalum capacitors are available in much larger values, but it turns out they are notoriously leaky, and tantalums are about as bad as electrolytics in this area – in other words, current flows between their anodes and cathodes at a fairly high rate.
Put that together , and you come up with this: never put an electrolytic or tantalum capacitor in parallel with the LED of an LDR, because it will create an alternate path for current to bypass the LED due to the leakage through the capacitor and that will adversely affect your ability to accurately control the current flowing through the LED in the LDR.
I think the best approach to designing a circuit to control the LED in an LDR is to go totally minimalist in the control path – you need a clean power source and precision current control. The fewer additional components in the circuit, the fewer places for current to wander off through and get lost. George’s circuit is good this way – no capacitors to muddle the current allocation through the LED -- just the potentiometer and LDR and possibly a trimmer.
Old 30th July 2013, 01:01 AM   #5100
wlowes is offline wlowes  Canada
wlowes's Avatar
Default makes perfectly good sense but..
wapo54001,
Your argument is logical and well thought out. However, build the attenuator using the simple circuit. Then solder 150uf OSCON SEP caps right on the power supply leads of each optocoupler. Listen again. I guarantee you will leave the caps in place.
To your argument however, perhaps it will sound even better if the Oscons are replaced with very low leakage PPE smt film caps. You could never get 150u. But a few 1uf smt caps might be interesting.
Lightspeed Attenuator a new passive preampHide this!Advertise here!
Copyright ©1999-2019 diyAudio
