Question on 12at7 preamp distortion
PRR
Joined 2003
Nope, only the negative wire. ...
Is that a NO or a YES??
You say you can not attenuate to zero. Yet this exact plan with a properly connected audio taper dual potentiometer was the core of many-many fine hi-fis, even in broadcasting where 2V levels were nominal. There are many ways to connect a pot and I can not see yours from here. Or from your terse posts.
....I also find the output stage WEIRD, certainly
not what I expected from the SRPP label....
I understand why the new guys don't call it by its right name. And that last drawing is tripped-out. But is it a White Cathode Follower. Has been since 1943.
Variations on the Theme of the White Cathode Follower
