Audiolabor Rein
Audiolabor Rein
Thread Tools
Old 14th September 2021, 07:21 PM   #1
iqpi is offline iqpi  Australia
Default Audiolabor Rein
Hi all,
I was wondering if anyone knows the input impedance for the MC phono stage of the preamp?
Not too much info about this vintage preamp.
Many thanks,
Aaron
Old 15th September 2021, 12:00 AM   #2
johnmath is offline johnmath  Australia
In this forum is was measured to be 1.4kΩ, if I read correctly.
Audiolabor "Rein" tönt dumpf im Phono- Eingang, Hifi-Klassiker - HIFI-FORUM
Old 15th September 2021, 07:23 AM   #3
Thanks John,
Yes, that how I read it as well, 1.4kΩ. Looks like I'll have to work with that number.
Old 15th September 2021, 02:29 PM   #4
as_audio is offline as_audio
More than one version of this preamp has been made,
with differences in the phono RIAA stage also.
Old 15th September 2021, 02:32 PM   #5
I have the one with the MM & MC if that helps? Apart from that how do I know which version do I have?
Old 15th September 2021, 02:35 PM   #6
If you are not sure a message to audiolabor.de may be helpful.
Old 15th September 2021, 02:40 PM   #7
Yes, I'll probably have to take the red pill and go straight to the source
Old 15th September 2021, 03:10 PM   #8
Looking at the schematic I think both MM & MC share the same phono input (although there are two pairs of RCAs). I will probably need to use impedance/capacitance plugs to match the cartridge and use the gain control to adjust. So I think the default is 47kΩ.
Old 15th September 2021, 03:26 PM   #9
See post 4.
Old 15th September 2021, 09:05 PM   #10
The notation on the schematic indicates that for MC either 1kΩ or 1k5Ω is paralleled with the 47kΩ input termination used for MM. That would imply an input impedance ~980Ω or ~1k45Ω.
  Reply to this post
Audiolabor ReinHide this!Advertise here!
Thread Tools
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
