Help me ID this potentiometer?
Thread Tools
Old 8th May 2021, 06:06 AM   #1
andrewhogge is offline andrewhogge
Default Help me ID this potentiometer?
Hi there,
I have an old Cello Palette Preamp and the main level pot has a weird lull/jump at 5 (12 o'clock) - right around that point one channel drops out slightly and the at 6 (1 o'clock) the volume jumps MUCH louder. There is no crackling so I'm not sure it would be a dirty pot. I've only ever changed out an alps blue 100k pot before, but this one I'm not familiar with. Its a 50k 10% but small white box shape and appears it might be even soldered down to the board beneath. Any help appreciated!
Old 8th May 2021, 06:16 AM   #2
OK I think its Vishay surface mount but not seeing one that has connections on top like this. Flipping over this board to see how many pins go through.
Old 8th May 2021, 07:32 AM   #3
Mooly's Avatar
That does look a weird thing.
You have to look how many pins in total. Three along one edge is a normal pot, a fourth pin (the one on top??) could be a tapping for a loudness circuit.
Old 8th May 2021, 08:52 AM   #4
johnmath is offline johnmath  Australia
Looks like a Vishay P11 option J (see page 13 in the data sheet linked):
https://www.vishay.com/docs/51031/p11sp11a.pdf
Old 8th May 2021, 09:06 AM   #5
H713 is offline H713  United States
H713's Avatar
Definitely a Vishay / Sfernice pot, and I would guess that the top terminal is some sort of loudness tap.
I'm surprised it's bad. Those pots are extremely high-quality (and seriously expensive). I consider those to be among the best small form factor pots on the market. Mouser carries some, and I know AML (audio maintenance limited) carries some as well. In all likelihood though, it's a custom part.
You could try contacting State electronics. They tend to handle all of the custom modular potentiometer tasks and have for a really long time. You'll pay, but they might have an option.
What's the shaft size and pin spacing?
Maintain a distance of at least 1 wavelength at 163.929 MHz from other other homo sapiens.
Old 8th May 2021, 11:04 AM   #6
Lampie519 is offline Lampie519  Netherlands
Lampie519's Avatar
I also use these pots sometimes but not with a center tap.
File Type: jpg B254520B-B14E-458C-B131-D0DC8A090844.jpg (434.2 KB, 143 views)
File Type: jpg F17EB871-CD85-43F5-BCA6-196350DDA56F.jpg (433.9 KB, 137 views)
File Type: jpg 36E7C4E1-5DBF-46F4-AA96-BA6940CE4C5E.jpg (413.0 KB, 134 views)
Old 8th May 2021, 11:50 AM   #7
Lampie519's Avatar
Maybe the source of the problem is not the pot as mentioned earlier. It could be the signal offered on the taps. Check if this is not out of phase or worse...
Old 8th May 2021, 12:49 PM   #8
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I would scope the pot as you turn it and see if the signal jumps.
Could be a coupling capacitor gone somewhere and upsetting DC conditions.
Old 8th May 2021, 05:03 PM   #9
H713's Avatar
Okay, looking at the price / value of this piece of equipment, the cost of a custom pot from State maybe isn't as big an issue as I thought. That would probably be my next course of action if I were the OP.
Old 8th May 2021, 10:57 PM   #10
Right, thank you for all the input!
I'm always a bit out of my depth here, but I do have a hunch its not the pot, just figured I might try to replace that first see if it fixed the problem, but yes its not your typical oxidization issue. When the pot is about half way turned there is a a discrepancy between channels for a very small portion of the turn and then it jumps in volume significantly. Only and always in the same position, its not intermittent.
I don't own a scope unfortunately, but I do know the local service on Cello gear is quite pricey so hoped to DIY if I could. Figured changing out the pot was the first step before losing more money and listening time putting it in the shop.
That Vishay looks close but correct its missing the tap. I haver to do quite a lot of disassembly to get it removed and check the pin spacing, but the shaft measures 6mm.
Pot is top right corner, but I will have to disassemble 4 more to flip the board.
Help me ID this potentiometer?Hide this!Advertise here!
Thread Tools
Help Wiring a Replacement Potentiometer for Sonic T Smokehouse Bob Class D 160 3rd May 2017 06:39 AM
DIY "ribbon controller" slide potentiometer-please help with blueprints! VvvvvV Instruments and Amps 4 21st January 2007 08:51 AM
Need some help with potentiometer. mkapszewicz Tubes / Valves 6 29th November 2006 04:55 AM
need help replacing potentiometer azalin Parts 3 26th May 2006 08:12 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
