2 pots in series
2 pots in series
Thread Tools
Old 28th April 2021, 06:10 PM   #1
diy1995 is offline diy1995
Default 2 pots in series
Hello,
I'm working on a project where I want to use 2 potentiometers in series.
First on for master volume, it's output would go to the amplifier and to the second potentiometer that would control the subwoofer level.
Potentiometers are digital (DS1803-100k), but for the sake of simplicity lets say they are analog. Only problem is that they need gnd (from power supply, not audio signal) supplied to L pin, they won't work without it.
Now I'm worried that the second pot will mess up the resistance of first one.
Can I do it like that or no?
Thank you for anwsers.
Old 28th April 2021, 06:38 PM   #2
rayma is offline rayma  United States
That connection would not work very well. The wiper is normally the output, not the input.
There will still be some interaction between the two pots, so the lower the pot values, the better.
Old 28th April 2021, 07:30 PM   #3
Hy, I would like to stick with these pots, I will try to wire them as you suggested on experimetal board and see what the result will be.
If interaction will be minimal I will be happy with it.
Thank you
  Reply to this post
2 pots in seriesHide this!Advertise here!
Thread Tools
Digital pots, better or worse than analogue pots ? nigelwright7557 Parts 12 12th August 2015 03:02 AM
FS: volume pots with bass tap and other pots flatheadmurre Swap Meet 0 3rd August 2012 06:12 PM
Sliding Pots vs Circular Pots for an equalizer inverseopamp Digital Line Level 13 27th April 2011 07:31 PM
POTS! Get Your POTS! SmarmyDog Swap Meet 7 29th October 2007 01:19 AM
Alps pots vs. TKD pots? TKD worth the extra$$? G Tubes / Valves 11 17th August 2004 04:33 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
