Storage Parts Build
Symbolic Layout so far
Possibly use the T-pad off my scrapped HP low signal generator as balanced attenuators as seen off the back of the HAIRBALL LOLA mic preamp output transformers... truly love taking advantage of that.
Good for today, happy or todays progress.
*Ian has POSTED his Poor Mans Tube Comp which will be implemented STEREO in this unit as an insert from the DA/interface — 1/4” — 1/4” out Instead of XLR
so it’s a currently a mono voice channel mic pre eq & then into the stereo tube compressor unit. I think that would be ideal instead of making two separate units (which will probably happen anyways)
Best blessings
