The bare chip. I'm building my own module for a Raspberry Pi 4 B 8GB sweet, this will simply be a DAC Amp module. I want to run pure class A on the output. This was the first time I'd looked at a DAC. I didn't expect a differential output, and I'm still not entirely sure which of several types of out is this differential output?
Is it a positive and a negative swing?
Is it they swing at the same time but in opposite directions?
I hear that there are design concerns because either the positive or negative are dominant over the other, is this an issue?
The recomended circuits requires an op-amp Low Pass Filter and a differential in single-ended pre-out. I considered alternatives and they weren't very good. I would've just used a coupling transformer but well I haven't given up on using a coupling transformer, but probably not.
It is described completely on Page 61 of the datasheet and on Page 9. They are 2.8 Vpp centered on half of the reference voltage.
AOUT (typ.@0dB) = (AOUT+) - (AOUT-) = +/-2.8Vpp * (VREFHL/R - VREFLL/R) / 5
The outputs are 180 degrees out of phase with respect to each other.
- Analog Line Level
- DAC Differential Outputs
