Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Thread Tools |
OK, go easy on me please... need advice before I do something stupid...
Looking to add a 60 second delay the simple way (I know there are many timer circuits, but this seems like a slap in and forget for cheap) SQUARE D 9050JCK13V20 Pros Heavy Duty contacts - Octal base - DPDT - 120VAC Coil - timer dial range .6 to 60 seconds See attached - 120VAC on Pin 2-7 activates 60 second relay - Left / Right channel outs to pins 1 / 8, ground on 4 / 5, final Preamp outs on pin 3 / 6. Can this be as simple as this for less that $15 (Used)? Since 120VAC, dangerous? Better sticking with lesser voltages?
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V Last edited by john65b; 3rd November 2020 at 01:19 PM. |
#2 |
Yes, for security reasons you don't want 120 Vac mains voltage next to signal carrying pins in an octal tube base.
Best regards!
"I spent a lot of money on booze, birds and fast cars. The rest I just squandered." (George Best) |
#3 |
For what reason this delay should be any good?
In practice, nobody needed a relais in a tube pre. There are some tubes with a controlled heater warm up time. This offers enough delay and was often use in the old days. |
#4 |
Controlled warm up time means that any tube in a series heater chain encounters the same time to heat up. It hasn't anything at all to do with delayed start.
Best regards!
#5 |
I have a nasty series of pops and cracks from a DIY tubeamp that have damaged downstream amps upon startup... once preamp circuit warmed up and stable, no issues at all.
I know I can just count to 60 and turn on amp after preamp, but would like a better, automatic solution....
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V |
#6 |
Use a DC operated, NC relay that matches the DC filament voltage in the preamp.
The relay switches the audio output either unmuted, or shorted to ground. Upon power on, after a preset delay, the relay opens and then the audio is available. Upon power off, immediately remove power to the relay to mute and prevent turn-off noises. You could use the 120VAC relay to switch the filament DC to another relay for audio muting. Last edited by rayma; 3rd November 2020 at 07:49 PM. |
#7 |
Yup, the 6.3vdc (in parallel to tube heaters) instead of 120VAC relay coil voltage is obviously a better solution (duh)...
Will start looking... I kinda like the octal socket setup tho...
#8 |
You can use both relays, as in post #6.
#9 |
I do not understand why I would want to delay the heater circuit 60 seconds while full B+ is being applied...urban myth?
Forgive my ignorance....
#10 |
The DC coil relay is powered by the DC filament supply. The filament supply is not switched by the relay.
The relay switches the audio output short to ground on and off. You could use the 120VAC relay switched contacts to interrupt the connection between the DC filament supply and the coil of the DC relay, and use the programmable delay of the 120VAC relay for the turn-on delay. This way you could use the 120VAC relay instead of an IC timer for the turn-on delay of the muting DC relay. Last edited by rayma; 3rd November 2020 at 09:03 PM. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Why wouldn't this work? | Surtsey | Multi-Way | 19 | 18th April 2020 01:16 AM |
Someone Told Me This Wouldn't Work? | mr2racer | Tubes / Valves | 23 | 19th August 2013 08:00 PM |
Why wouldn't this work? | millwood | Solid State | 34 | 13th July 2003 05:03 PM |
New To Site? | Need Help? |
