Ultra low drift GAIN
Old 16th August 2020, 01:45 PM   #71
mchambin is online now mchambin  France
Referring to posts #44 and 45.
Indeed, Phythagora is welcomed.
To see the effect of the open loop gain on the loop gain, I can write for a non inverting stage with resistors to set the gain g0
g0/g = 1 + g0/G
Where
g is the actual closed loop gain
g0 the expected closed loop gain
G the open loop gain.
This is valid at DC.
This is valid too, at any frequency considering G is a complex number one could derive from the gain, phase plots from the datasheet.
At DC no problem, G is typically over 120dB, so with g0 =8 we have g/g0 better than 8ppm
At hight frequencies, it is not so fine because G is much lower. Assuming GB 10 MHz, at 20 KHz we only have G = 500 which gives
g/g0= 1 - 0.016, so terrible 16 000ppm.
Here comes Phythagorus, telling this result is wrong.
Indeed, G is not a real number, this gain has typically a phase -90.
This is consistent with post #44 and confirmed with post #45 where a plot shows phase -90 over frequencies from 100 Hz to 100KHz.
So at 20KHz, actually g/g0 = 1 + j 0.016
from Pythagora this gives 128ppm a totally different story.
All the above is about gain flatness.
To adress gain drift, all the above results have to be multiplied by the accuracy of G
Considering G has TC 0.1%/℃
Gain drift at 20KHz becomes 1ppm /℃
Transistor junction temperature is not transistor case temperature.
  Reply to this post
Ultra low drift GAINHide this!Advertise here!
Oscilloscope X-Y Drift ragwire Everything Else 2 5th December 2015 12:35 PM
Ultra Low Noise - Ultra Low Impedance - Ultra big Problems! Stefan0815 Analog Line Level 2 14th January 2014 06:01 AM
BOZ voltage drift GregH2 Pass Labs 0 21st March 2012 02:10 PM
Bias Drift AmpBuilder225 Tubes / Valves 9 4th November 2009 04:38 PM
Seeking ultra, ultra mini 1uF elec cap Triophile Parts 11 6th April 2005 11:17 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
