Dynaco PAS-4 (yes, 4) a little bass shy, need help
Old 25th May 2020, 01:15 PM   #1
robertb1958 is offline robertb1958  United States
Default Dynaco PAS-4 (yes, 4) a little bass shy, need help
I recently picked up one of these, mildly moded by the PO. The pre sounds wonderful throughout the mids, very 3d. But the line section seems a little wimpy on bass. The phono section sounds just fine compared to other good phono sections.
I think the only mod that the PO did was to substitute 1 microfarad Mundorf caps for the C9/C109 ooutput coupling caps that should be 3.3uF per the schematic.
Wondering if I should put some 3.3uF caps back in? Line stage tubes are Amperex bugle boy 6DJ8s, those should be good. I could roll in some other tubes, or maybe test them on my Eico?
Would appreciate any input.
Old 27th May 2020, 08:12 AM   #2
duncan2 is online now duncan2  United Kingdom
Looking at the Dynaco-PAS-4 circuit diagram it shows -
C9/C109 as =1uF- polypropylene,
this is shown also in the parts list.
Dynaco PAS-4 - Manual - Vacuum Tube Preamplifier - HiFi Engine
There is no sign of =3.3uF capacitors.
Old 27th May 2020, 08:46 AM   #3
Thank you, Ducnan.
Interesting, the online diagram I found elsewhere indicated a 3.3uF in that position.
I found that I had some 6DJ8 tubes on hand, rolled them in. I think they helped the high level section bass response. They tested a little stronger in my Eico 667.
Old 27th May 2020, 08:01 PM   #4
dotneck335 is offline dotneck335  United States
That preamp wants to see a high-impedance load, for sure, like ≥100KΩ. If your load is less, you may see some performance losses. Putting in a higher-value cap certainly won't hurt anything, and may improve bass response into a lower impedance load.
  Reply to this post
Dynaco PAS-4 (yes, 4) a little bass shy, need helpHide this!Advertise here!
Dynaco A25s bass performance pjblakey Multi-Way 5 17th August 2017 11:57 PM
Corner bass reflex maximally flat or extended bass shelf tuning? majerjack Multi-Way 8 18th December 2015 11:12 PM
Onken bass box with 2 Eminence Deltalite ll 2510 10" bass drivers albertli Multi-Way 37 2nd February 2015 02:46 PM
preamp suitable for Dynaco st-70- OTHER than dynaco namatjira Tubes / Valves 3 22nd December 2011 01:21 AM
For all Bass Junkies out there (Behringer Bass processor usage report) VEC7OR Digital Line Level 5 27th October 2003 09:18 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
