Chinese FU32
Chinese FU32
Old 22nd May 2020, 08:08 PM   #1
Kjeldsen is online now Kjeldsen  Denmark
Default Chinese FU32
Is it any good
#Aliexpress US $63.19 21%OFF | Nobsound Mini FU32(832A) Valve Tube Amplifier Hi-Fi Stereo Preamp Desktop Tube Headphone Amp
Nobsound Mini FU32(832A) Valve Tube Amplifier Hi Fi Stereo Preamp Desktop Tube Headphone Amp|Amplifier| - AliExpress
I don't have a specific purpose. I just think it look Uber cool. Could it be used as a buffer for pascal spro2 module. Or only as headphone preamp? I also have have a Kt120 class A amp that also need some fun stuff
http://kjeldsensforbindelser.dk
Old 22nd May 2020, 11:48 PM   #2
PRR is online now PRR  United States
PRR's Avatar
Chinese FU32
> Is it any good ........ I just think it look Uber cool.
Who cares if it works at all?? It IS uber-kewl.
Old 23rd May 2020, 06:38 AM   #3
Looks means a lot to me, especially if it's also some kind off odd looking. But it also needs to work
Old 23rd May 2020, 07:26 AM   #4
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Reading the blurb, translated from Chinesium, it is very susceptible to noise from phones, switchgear and motors.
Not a lot of good for a pre amp!
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 23rd May 2020, 07:31 AM   #5
I also see it have an op amp in the circuit. Most likely for input instead of tubes. I assume it's more looks than quality sound.
If anybody know a simple silent tube buffer with low zout, then feel free to put in a link. I don't mind soldering, but I also don't mind if it's ready made
Old 23rd May 2020, 07:33 AM   #6
tomtt is offline tomtt
tomtt's Avatar
Location: kansas city mo, and on occasion, around the world ...
Agreed
Modern sculpture.
internet photographer
Old 23rd May 2020, 08:30 AM   #7
ACF 12Vac Tube Stereo Buffer
Maybe an option if it can drive the low input impedance of my Pascal spro2 modules
Old 23rd May 2020, 11:56 AM   #8
Mark Tillotson is offline Mark Tillotson
Highly dangerous too, you can see the anode cap connections are not fully protected from
prying fingers - this is a child-killer.
Old 23rd May 2020, 03:49 PM   #9
pcan is offline pcan  Italy
Chinese FU32
The anode connection on FU32 chinese kits is scary. The wire itself is almost always a thin low-voltage, low-temperature wire because it must fit inside the holes on that ceramic base; the insulation will melt or crumble after a while. The most common anode supply on this kind of circuits is 250V only, so the ceramic cap is not needed at all. I use a bare Molex crimp connector wrapped in fiberglass reinforced tubing, and the wire is a 1000V, high temperature type.
By the way, FU32 / 832A is a fun tube. I have built a 3+3w single ended amplifier mostly for the way it looks. I haven't found any sonic advantage over a conventional 6V6 build, and there is the added issue of a concentrated heat source. But I can ensure to Kjeldsen that this tube, with filaments turned on, is even more cool looking than the linked picture. The amplifier referenced on post #1 looks to be badly engineered and does have poor ratings, but there are several better kits and prebuilt amplifiers from China. They look to be more expensive than sourcing two Hi-Fi 5W output transformers from a reputable manufacturer, a genuine RCA 832A tube, a dual triode, and the few more parts required by the schematic. Maybe I will try a 829B next time.
Old 23rd May 2020, 05:11 PM   #10
For lower power the QQV03-10 dual-tetrode (near equiv. 6360) avoids anode caps, being standard 9-pin.
Chinese FU32Hide this!Advertise here!
Chinese 6J1 + FU32 Class A SE 3+3 W pelanj Tubes / Valves 7 24th October 2019 07:53 PM
FU32 4 channel amp Jamh Tubes / Valves 1 25th March 2018 10:42 PM
6N2+FU32 transformer output headphone amp siliconray Siliconray Online Electronics Store 3 23rd October 2014 02:35 AM
adapting a FU32 Tube amp for QQE 03/20 tubes? thedoci Tubes / Valves 1 29th September 2014 09:50 PM
6n2 + fu32 vacuum tube tube headphone amplifier jhin Headphone Systems 1 12th November 2013 03:23 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
