Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Thread Tools |
#341 | ||
The Dastardly Dad of Three
The schematic i used was (post#51): Mean well vs generic power adapter vs audio oriented smps Quote:
#342 |
Thanks for the book links Mark, I love the subtitles "A Handbook of Black Magic" and "Advanced Black Magic"
![]() Very good point about the ground being noisy in a poor setup preventing meaningful measurements. I used a differential configuration (pin 2 to PSU+ and 3 to PSU- on an XLR, using blocking caps in both) to feed the ADC it seemed to help reduce common mode noise. I just got the boards from konst so I'll get a couple of filters built for experimenting. |
#343 |
Has anyone installed this circuit inside the Korg Nutube B1 pre- amp case or is this a no no? thanks
#344 |
I've installed it inline with my B1 Korg Balanced version, works very,very well! Mark Johnson even suggested using two in series, I just finished another to try that as well. The B1 Korg is exactly what this filter is for, I have seen external versions inline, and the filter installed inside the enclosure with the B1 Korg.
#345 |
Thanks, reading and seeing in in a small external box but no images of it actually in a Korg case got me thinking maybe there is a reason that I am not seeing . cheers
#346 |
I'd love to get a couple boards for my NuTube preamp. What is the best way of getting them? Is there some sort of a group buy or does anyone have extras? I'dbe glad to pay my share. Thanks!
#347 |
Quote: Has anyone installed this circuit inside the Korg Nutube B1 pre- amp case or is this a no no? thanks
It is a YES YES! Absolutely recommended and no problem whatsoever to be in the same casing. Tried daisy chaining 2 but (perhaps as...) my B1 Korg is already tweaked re PS (low ripple PS + 2200uF caps), it made no real difference - but of course always worth a try. Next step is to try Mark's enhenced version with the better caps and daisy chaining aswell. Whatever is best will come in the casing permanently with my B1 Korg. Mark's filters are really good and nonexpensive, it is IMHO always worth to build a few more: you will always find an application sooner or later and of course you can experiment a lot of combos that way. Have fun Claude |
#348 | |
I have several boards left over from a recent order. Please pm me with your address and I'll let you know the shipping cost. The boards are free.
A poor life this if, full of care We have no time to stand and stare. Last edited by SuppersReady; 23rd January 2021 at 08:24 AM. |
#349 |
I'll be installing the filters inside the nutube case when the bench is clear of its current project. The plan is to use the slots in the sides of the case for mounting them without having to drill any holes.
A poor life this if, full of care We have no time to stand and stare. |
#350 |
Which leads me to another thought. The plan is to permanently install these filters in all of my current preamps (AKSA Lender, B1K, ACP+, Starving Student x 2). At some point in the near future I aim to put together a linear power supply to compare with the SMPS.
Is there any issue with using a linear power supply with these filters in circuit? I can't see that there would be, but I'm no expert in these matters.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Korg NuTube B1 guide | 6L6 | Pass Labs | 8 | 14th October 2020 07:59 AM |
Korg Nutube B1 Pre-Order Q&A | Jason | The diyAudio Store | 33 | 14th October 2020 07:55 AM |
Korg Nutube | pmoyle111 | Tubes / Valves | 6 | 24th April 2020 11:41 PM |
Korg NuTube is now available online | pmillett | Vendor's Bazaar | 156 | 24th December 2019 12:33 AM |
WTB: Firstwatt Korg Nutube B1 (or just PCB) | Brzzl | Swap Meet | 2 | 4th September 2019 10:54 AM |
New To Site? | Need Help? |
