Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Thread Tools |
#321 |
I've been having fun today trying them out with my ACP+ and Grado 325s. You can hear a difference with one in circuit. The difference with two is even better. Lots and lots of extra musical details. Spatial positioning of instruments is truly excellent. Now I just need to get a case and then try it through my main system.
Second opinion from SWMBO, "It's like putting your glasses on, it brings things into focus." This afternoon's project is to try them out on the Starving Student II and, if time allows, the B1K in the office system. I hope that you all enjoy them too.
A poor life this if, full of care We have no time to stand and stare. |
#322 |
Pictures please.
#323 |
Last night I tried the Salas UBiB regulator on my B1Korg, the benefits of hte PO89ZB are very much evident even with that low noise regulator. The measurable (with my skills) difference in noise seems to be very small, yet it realy does work even there
#324 |
This is very interesting. I tried to make a filter like this with inductors I pulled out of a switching power supply. It did attenuate the noise, but not nearly enough. It made a slight improvement but the headphone amp clearly sounded better with an old fashioned wall wart powering it.
I was wondering if the circuit could be scaled. For line level circuits and class AB headphone amps I was thinking of using 0.4 ohm or 1 ohm series resistors. It sure would be handy to use some of these laptop supplies for audio projects. Inductors out of stock https://www.mouser.com/ProductDetail...BdHMSEZA%3D%3D but they're affordable and not too big. |
#325 |
Completed 24v supply for Korg B1. Filter in the corner.
“ The simpler you can make an amplifier, the more likely there is a good correspondence between the sonic performance and what you measure on a bench.” N.Pass |
#326 |
diyAudio Donor
Lovely build, @Monk55! Wasn't expecting to see a 200 watt SMPS (140 watts without fan) in there.
#327 |
Since you asked 1883,
Not pretty, but easy enough to do. It allows me to try it on any of my preamps.
A poor life this if, full of care We have no time to stand and stare. Last edited by SuppersReady; 17th January 2021 at 10:26 PM. |
#328 |
Thank You
#329 |
Just about as small as can go...
Boxes: LeMotech 5 Pieces Plastic Project Box es Junction Case for Electronic Project, Black 3.15 x 1.97 x 1.02 inch (80 x 50x 26 mm) Jack’s: 5.5 x 2.1 MM 10A DC Power Jack Socket Dc099 30V Threaded Female Mount Connector Adapter with 3.94 Ich 18AWG Cable and DC Barrel Jack Plug Male Lsgoodcare Siliconed board to box.
“ The simpler you can make an amplifier, the more likely there is a good correspondence between the sonic performance and what you measure on a bench.” N.Pass Last edited by Monk55; 18th January 2021 at 02:13 PM. |
#330 |
The Dastardly Dad of Three
These are awesome ! I also enjoyed the company of a super simple (standard 5 component) cap multiplier after the passive filter ... just sayin
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Korg NuTube B1 guide | 6L6 | Pass Labs | 8 | 14th October 2020 07:59 AM |
Korg Nutube B1 Pre-Order Q&A | Jason | The diyAudio Store | 33 | 14th October 2020 07:55 AM |
Korg Nutube | pmoyle111 | Tubes / Valves | 6 | 24th April 2020 11:41 PM |
Korg NuTube is now available online | pmillett | Vendor's Bazaar | 156 | 24th December 2019 12:33 AM |
WTB: Firstwatt Korg Nutube B1 (or just PCB) | Brzzl | Swap Meet | 2 | 4th September 2019 10:54 AM |
New To Site? | Need Help? |
