Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Thread Tools |
#301 |
Was there ever a consensus on a substitute for the 2.2uH coil that is on back order ?
#302 |
Thanks Kasey
Do you perhaps have a schematic showing how you connected both SMPS at the input/main and at the output? I had a look at the Mean Well you mentioned. My knowledge of SMPS is limited. My understanding is it might be feasible on some to connect + of one unit with - of the other to form the ground / amp 0V. I would have thought though it depends on the technology used for the SMPS and would per definition only apply if not connecting any part of the SMPS to ground, that is having only on the side of the mains L and N connected with 120 or 240V AC depending on the country... and no ground. Is that correct? If so, how to ground the units? I know my old amps only have L and N but when dealing with a big Class A or AB amp with heavy dual voltage (say +40 and -40V and over 10A per phase and channel) I guess knowadays people would for safety reason have a ground at the mains? Thanks again for your help, SMPS could open a brand new field of possibilities, if only it were quality dual phase... Claude |
#303 |
Re coils, mine are due in 2 weeks, and (chicken, I know...) I perfered to stick to what I knew and was recommanded. Enough variables and risks running my company - when dealing with hobbies they have to be quite straightforward :-)
Plus I would probably have the parts lying around, in time indeed but me not being available LOL - what are 2 extra weeks on MY audio projects? Will though introduce a new variable in form of the latest caps... and report Claude |
#304 |
Looking forward to your findings !!
Great info as usual ! |
#305 |
I ordered the boards from JLPCB. It couldn't be any easier. Got them in a week or so.
Components came from Mouser. Yes, the coils are on back order, but I'm in no hurry. Figured I'd just get all the components on the same BOM as opposed to a Mouser/Digi Key split order. It's easy to add the components and you can complete a board in 5-10 minutes. |
#306 |
diyAudio Donor
oooooh. The super low ESR Nichicons. excellent.
#307 |
I bit the bullet & bought from 2 sources...got plenty of parts....waiting on boards to arrive...even have several different boxes.
“ The simpler you can make an amplifier, the more likely there is a good correspondence between the sonic performance and what you measure on a bench.” N.Pass |
#308 | |
diyAudio Moderator Emeritus
The Benchmark video is advertising and it is also not exactly the standard cheap SMPS as generally found. What often seems to be forgotten is the pollution many SMPS produce at the mains side of things. And the RF emission .... the short life of many of them ... the wearing out of caps at the higher frequencies... the wining noise they often make .... It is like class D, when that started people were complaining of cold sound, non musical blah blah. Nowadays class D is the new standard according to many ![]()
It's only audio. Member of the non modular PCB design committee Last edited by jean-paul; 13th January 2021 at 11:07 PM. |
#309 |
These are so nice! Thanks Mr Johnson
#310 |
There seem to be two pages at Mouser for the inductors. This one shows them in stock.
Pronouns: they, them, etc • System: DIY Turntable, Graham 2.2, Grado Statement Master, XP17 & XP20, Schiit Yggdrasil, Logitech Transporter, Aleph 1.2s, Dynaudio Contour 60s, Gotham Audio Cables • DIY Builds: Whammy, SS II, Balanced B1 |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Korg NuTube B1 guide | 6L6 | Pass Labs | 8 | 14th October 2020 07:59 AM |
Korg Nutube B1 Pre-Order Q&A | Jason | The diyAudio Store | 33 | 14th October 2020 07:55 AM |
Korg Nutube | pmoyle111 | Tubes / Valves | 6 | 24th April 2020 11:41 PM |
Korg NuTube is now available online | pmillett | Vendor's Bazaar | 156 | 24th December 2019 12:33 AM |
WTB: Firstwatt Korg Nutube B1 (or just PCB) | Brzzl | Swap Meet | 2 | 4th September 2019 10:54 AM |
New To Site? | Need Help? |
