Active crossover
Active crossover
Old 3rd April 2020, 09:14 AM   #1
Jonas22 is offline Jonas22  Lithuania
Default Active crossover
Hello,
I wish to built 2-way active crossover with 1300 Hz cutoff frequency.
I have theorical schematics, please see Figure 5 and 6 in link bellow:
AM Active Crossovers
But I don't know how to calculate all components nominals.
Maybe someone know equations or maybe can calculate these values?
Best regards,
Tadas
Old 4th April 2020, 01:42 AM   #2
PRR is offline PRR  United States
PRR's Avatar
Active crossover
ESP Projects Pages - DIY Audio and Electronics
Old 4th April 2020, 03:00 AM   #3
elukacs is offline elukacs  Hungary
If you are happy with different topology then here you can find a decent paper and solution from TI.
https://www.ti.com/tool/TIPD134
Paper also shows how you can use TI filter design tool to change xover frequency.
In the lower section of the page they also included a TINA sym model if you want to check the changed circuit.
Old 4th April 2020, 03:35 AM   #4
keilau is offline keilau  United States
linkwitzlab_activefilters.pdf
Linkwitz_Riley_Crossovers_Primer-Rane.pdf
I hope that you will find these article from the former Linkwitz Lab helpful.
I will also strongly encourage you to consider a ready built box from Weilliang Audio. You can specify the crossover frequency when you order. This one is head and shoulder above other Chinese offers. I replaced the 5532 IC with LME49720 genuine product. The result is excellent.
WEILIANG AUDIO Linkwitz Riley electronic frequency divider two frequency division preamplifier custom crossover point|breeze audio|electronic crossover|crossover electronics - AliExpress
Old 4th April 2020, 08:46 PM   #5
Thanks guys, but I want to try gyrators based schematic. I only need equations to calculate preferred values.
Old 4th April 2020, 09:01 PM   #6
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Active crossover
How steep do you need the XO? If 1st order you might get away with a PLLXO, which is both cheap and adds no "electronic haze” (but at the expense of versatility). What drivers are you using?
And do note that a basic active XO does not usually deal with specific driver issues that a passive often solves.
Stay safe. Stay home. Respect the 2m bubble.
Old 4th April 2020, 09:09 PM   #7
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
For your purpose, look at TDA 2320A datasheet (> applications)
thereís no staying at home when you do not have one
  Reply to this post
Active crossoverHide this!Advertise here!
Do i need analog active Crossover or Digital Crossover for DIY home theatre speakers? dipankar862 Multi-Way 43 16th March 2017 05:55 AM
Help needed to decide: DIY Active Crossover or Passive Crossover? raelman Parts 5 1st October 2014 03:19 PM
Can you use a digital active crossover to design a passive analog crossover ? RickDangerous Digital Line Level 27 1st April 2013 05:59 AM
Active Crossover: Behringer x DBX active DriveRack 260 murillollirum Multi-Way 21 9th February 2013 07:12 AM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
