Sub woofer
Sub woofer
Old 6th April 2020, 11:27 AM   #21
BJosephs is offline BJosephs  United States
Originally Posted by Charan Raju H View Post
Thank you very much.
But I didn't understand what is 7 inches of 6 inch drain pipe? Is that a port dimension?
PRR is giving examples of acceptable enclosure volumes. He is comparing a 4 liter rectangular box to a piece of tube with the same internal volume to indicate that both are reasonable test enclosures for your sub.
Typically you can connect a modern device’s output to multiple inputs if both devices are high impedance. Two amp inputs would probably not strain a cell phone’s output jack, especially given that those jacks can drive headphones. You should assume that the lower the load the higher the distortion.
  Reply to this post
Sub wooferHide this!Advertise here!
Audax pr170mo Woofer selection... which 15 inch woofer 98db eff... youknowyou Multi-Way 15 20th June 2017 05:37 AM
compromise = small woofer - larger (horn) midbass - what woofer types blend well? freddi Multi-Way 1 31st October 2015 12:15 PM
Woofer-Fullrange-Woofer vs Tweeter-Midrange-Woofer fakeout Multi-Way 5 11th August 2012 06:17 PM
WTB: 6.5" woofer to replace broken woofer in cheap band pass subwoofer Jimmy154 Swap Meet 2 5th October 2010 02:00 PM
Woofer replacement for Infinity Reference 2000.5 Woofer kchilaka Multi-Way 0 28th September 2010 05:11 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
