Add a channel to parametric equalizer Rod Elliott Project 150
Old 27th March 2020, 05:57 AM   #1
wonderfulaudio is offline wonderfulaudio
Default Add a band to parametric equalizer Rod Elliott Project 150
Rod Elliott's project 150 shows schematic for a single band parametric equaliser.
Parametric EQ
How does one add another band to it?
Thanks,
WA
Old 28th March 2020, 02:15 AM   #2
PRR is online now PRR  United States
PRR's Avatar
Old 28th March 2020, 12:58 PM   #3
Mark Tillotson is offline Mark Tillotson
And you'll need a 2-gang pot for the cut/boost VR2, and a 4-gang pot for the frequency VR1.
Alternatively you could replace the piggy-backed 10k linear pot for the frequency with
a single 10k log per channel, thus only needing a dual log 10k pot for frequency for two channels.
Old 29th March 2020, 04:39 AM   #4
PRR's Avatar
I would call that a single channel with double-strong action.
I thought he wanted a bass +and+ a treble.
I agree the question can be read several ways.
Old 29th March 2020, 04:53 AM   #5
I replaced the 'channel' with 'band' in the original question.
Thank you all for your responses
Old 5th April 2020, 12:18 AM   #6
dotneck335 is offline dotneck335  United States
You could use this:
Eight Band Sub-Woofer Equaliser
and just adapt it for wider-band use.
Add a channel to parametric equalizer Rod Elliott Project 150Hide this!Advertise here!
Car audio parametric equalizer chip wonderfulaudio Digital Line Level 3 3rd August 2018 01:57 PM
Problem with parametric equalizer karha096 Analog Line Level 10 2nd March 2014 09:07 AM
anti-sin(x)/(x) for NOS DAC via software parametric equalizer new2hifi Digital Line Level 9 14th December 2012 06:52 AM
DIY subwoofer parametric equalizer SSassen Everything Else 1 1st June 2005 02:48 PM
Parametric equalizer software Milo Everything Else 4 20th April 2003 02:56 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
